Old 02-15-2006, 11:49 PM
john1880  is offline
Posts: 468  -  iTrader: (1)
Anyone interested in a Drop D for lo-pro Edge?
Hey guys,
I have made a Drop D lever that fits on the back of a Lo-Pro Edge and I will be making a couple for myself. There is no modification needed to the guitar or the LO-pro other than needing to block the trem or use a trem stalizer(which is what i do).
Any of you guys interested in something like this? The price would be about $50.
Thanks.
John
Old 02-15-2006, 11:50 PM
john1880  is offline
Re: Anyone interested in a Drop D for lo-pro Edge?
sorry. trem "STABILIZER"...
Old 02-17-2006, 12:29 PM
Entropy  is offline
Posts: 231  -  iTrader: (1)
yeah...definitely interested.
what's the material it's made of?
can you post a pic of it installed?
Do you think it will do a drop-A on a 7string?
Old 02-17-2006, 09:45 PM
john1880  is offline
it will be made of stainless steel or tool steel. probably stainless steel. i can't post a pic yet because the design is still unprotected right now. i have a seven string. i'll check that out and let you know. thanks.
Old 02-18-2006, 01:04 AM
ibanez.shredder  is offline
Posts: 310  -  iTrader: (0)
I would be very interested in two or three of these. I'm guessing you are going through the patenting stage now so we can get a look at the design? Also, how do you construct it? CNC, lathe, milling, casting, forging or something else? i'm just asking because if i was going to get something like this, it'd be great if it was well made and lasted as long as the trem. Keep up the good work! Cheers
Old 02-18-2006, 09:58 AM
Chud  is offline
Posts: 926  -  iTrader: (0)
Yeah i'd be interested in one for a 7-string, though my trem is a Lo TRS.
Old 02-18-2006, 08:25 PM
Ant1981  is offline
Posts: 2,181  -  iTrader: (3)
There already is a stabilizer available
Old 02-19-2006, 05:59 PM
john1880  is offline
These will be milled from a solid piece of Stainless steel on a CNC, and I designed it on a Mastercam program. I have made a version for the regular Edge from the same material and it shows no where after a year, and I drop D a lot.
Chud, this will NOT work on a non lo-pro, but the D-tuna may work for you.
Yes, I am in the beginning of the patent stages, so once I can release the design, I will email pictures to those of you who are interested.
Ant1981: this is not a stabilizer. It's a drop-D attachment for the Lo-Pro.
Thanks!
John
Old 02-19-2006, 06:19 PM
Marko@Rockvoice  is offline
Posts: 139  -  iTrader: (1)
What about the edge pro tremolo?
Old 02-19-2006, 10:35 PM
Ant1981  is offline
How does it work John?
Usually I would use a stabilizer and use the fine tuner wound in to tune to E then wind it out to drop to D.
Without the stabilizer, every other string goes slightly out of tune as the tension of the E string slackens as it is dropping to D.
Old 02-20-2006, 11:16 PM
john1880  is offline
i don't have an edge pro. if i can get a look at one i will let you know.
ant1981: yes, you still need a stabilizer, but now you would just pull the lever out and it's in Drop D position. push it in and it's back up to E. Just like the EVH Dtuna works, but it's a completely different design since the EVH wont wotk on lo profile trems.
Thanks.
edge pro trem, edge pro tremolo, pro edge, pro tremolo
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
Anyone interested in a Drp D for lo-pro Edge? john1880 Polls 4 03-22-2006 01:38 PM
Drop D tuning on an Edge Pro atarilovesyou Other Ibanez Guitars (including Premiums) 3 11-23-2005 12:20 AM
edge, lo pro and edge pro are 100% drop in fit dex Tech: Setup, Repairs and Mods 47 10-18-2005 12:29 PM
EVH drop D tuner on Edge trem Black Star Tech: Setup, Repairs and Mods 6 07-21-2005 06:49 PM
