B String is lower and Copping a Buzz ;)
Ok, since I got my Jem, it's had bad buzz at the first fret for the G B and E string. Today I shimmed the nut, so now the only buzz is coming from the B string.
I thoroughly inspected the bridge and nut for this particular string and found that it is lower than the others. I checked the saddle and it seems to be at the appropriate level and the nut string spaces are equally level the same depth.
I made sure all the frets were aligned and even dressed the first fret down the smallest bit...but the buzz only seems to be occuring on this string.
What can I do to fix this with the exception of a saddle shim?
The other frets still have the smallest buzz too, FYI.
