Tech: Setup, Repairs and Mods
Bad intonation problem, please help.
09-07-2007, 09:18 AM
ChopDuel
Posts: 27 - iTrader: (
Hey guys, I recently started to experience a really bad intonation problem on the high E and B strings. It is so flat, that sometimes the 23rd fret shows as a sharp D on the tuner instead of D# for example, moving the saddles forward doesn't help cause they are already as forward as they can be without touching the pickguard during dives.
Has anyone experienced this before?
I know it has to do with old strings and my strings are not exactly new but i never had this problem so bad even with old strings before.
another thing that could be related to this, is when i play a note, usually above the 12th fret on the B string, it gives this kind of dissonant vibration that you can hear if you play 2 different notes at the same time, even though it is just a single note.
ChopDuel
Find all posts by ChopDuel
09-07-2007, 10:24 AM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
Re: Bad intonation problem, please help.
Sounds to me like the truss needs to be adjusted a bit.
Jimmy
jb4674
Find all posts by jb4674
09-07-2007, 10:29 AM
Algiman
Posts: 2,553 - iTrader: (
A couple of times now I've been setting guitar up, with new strings, and found that the intonation was ridiculously out. Usually it comes down to a dodgy string - even new. Gibson's own strings seem to be the worst for it but I've had it happen with D'Addario's too.
Leave the
truss rod
alone, get new strings on, and try again.
Algiman
Find all posts by Algiman
09-07-2007, 10:58 AM
eviltwin
Posts: 1,629 - iTrader: (
this may be related to magnetic pull, the pickup being too close to the string. easily checked by lowering PUPs.
eviltwin
Find all posts by eviltwin
09-07-2007, 11:51 AM
ChopDuel
could old strings affect the intonation that much?
the reason this all seems strange is that it was never so bad im similiar situations, i havent changed the
pickup height
in a while and i did have some pretty old strings at times
ChopDuel
09-07-2007, 06:12 PM
ryanb
Posts: 1,457 - iTrader: (
Change the strings first before you do anything else (and re-intonate, because if the saddles are all the way forward the intonation is already wrong). If you still have a problem then, you can investigate further. It's probably just bad string(s).
ryanb
Find all posts by ryanb
09-07-2007, 06:23 PM
shogun
Posts: 1,525 - iTrader: (
ChopDuel
strings arent fit for intonation unless they havent been played (with the exception of stretching.)
shogun
Visit shogun's homepage!
Find all posts by shogun
09-07-2007, 09:25 PM
ChopDuel
shogun
i dont quite understand you. what did you mean to say?
ChopDuel
09-12-2007, 09:04 PM
ChopDuel
ok i put new strings on and intonation is perfect now
thanks guys... never thought the strings could become THAT bad.
anyways, now i hope wd-40 won't let me down in keeping them new.
ChopDuel
09-12-2007, 09:28 PM
sniperfrommars1
Posts: 3,302 - iTrader: (
I use A product called finger ease now. It lubes my fretboard well, and keeps the strings slick and new. It isnt greasy at all which is what i like about it and smells frickin awesome.
sniperfrommars1
Find all posts by sniperfrommars1
09-12-2007, 09:30 PM
David McCarroll
Posts: 2,049 - iTrader: (
ChopDuel
the reason this all seems strange is that it was never so bad im similiar situations, i havent changed the pickup height in a while and i did have some pretty old strings at times
You bet they could! A set of seriously old corroded strings could make your intonation drift nearly a semitone by the end of the neck - and like someone else said, you DO get bad strings (from Gibson? gee, what a surprise!) - with a really odd intonation problem that suddenly shows up - first stop should be changing the strings. In this case, as there is also a "warbling" sound, I'd also be asking if the guitars pickup height has been adjusted lately.
David McCarroll
Find all posts by David McCarroll
09-21-2007, 01:36 AM
Kasper Kowalski
Posts: 118 - iTrader: (
ChopDuel
I doubt it was the strings themselves... probably more to do with them being stretched out and the bridge no longer parallel to the body (assuming floating bridge).
I have some pretty ancient strings on a couple of my guitars, but I make sure the geometry of the guitar is correct always - never have an issue with intonation.
Kasper Kowalski
Visit Kasper Kowalski's homepage!
Find all posts by Kasper Kowalski
12-06-2010, 07:19 AM
xxrifferxx
Posts: 1 - iTrader: (
the EXACT same thing is happening to me. i have changed the strings, intonation has become fine after that, but as you said, i have played on my other guitars with old strings, but the intonation was fine for them. i don't think the problem is solved yet. you can keep on changing the strings, but remember, that you have played on old strings before without the intonation becoming bad, so it's not only the strings. something else is also involved. if you don't solve it, you're gonna be wasting money by changing an entire set just because the E and B are screwed up; you're gonna be changing sets faster than you normally do because of this intonation problem.
xxrifferxx
Find all posts by xxrifferxx
pickup height
truss rod
how far off intonation in cents
how bad is 10 cent sharp within intonation?
guitar solo problem when recording
problem frequencies when mixing
intonation makes strings tighter?
intonation problem
mr.jem555
04:02 AM
Little intonation problem (RG470)
Spekko
12:34 AM
UV777BK Intonation Problem
Vegas_Blues
04:44 PM
String intonation - weird problem
carlos seo
09:13 PM
Intonation & tuning problem.
jetfixer
09:50 PM
03:27 AM
