Old 10-04-2003, 01:58 PM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
Blocking an Edge Pro
(mods: i searched this, but haven't found it)
a friend of mine brought his new 1527 to have me blocking the trem for pullings. he would just dive-bomb with it.
i passed a couple hours trying to find out how to put a wooden block in it, but it's quite hard cause the Edge Pro's sustain block is not as plain and flat as Edge/Lo-Pro's, it's kind of 'round', so anything you would put there, it will just work as a pivot for the trem.
can someone help me?
Old 10-05-2003, 03:07 PM
Rich  is online
Posts: 19,348  -  iTrader: (21)
I see no reason to worry about it, it's still only going to make contact in the *center* of the block
Old 10-06-2003, 04:15 AM
nuno  is offline
but it can't stay blocked.
the rounding has not vertical axis, but horizontal axis.
hard to explain for a non mothertongue.
Old 10-06-2003, 04:53 AM
Rich  is online
[Had to go grab one, not like I ever looked at one to figure how to block it]
Your easiest block is the vertical axis, slip a piece between the body and the block at it's fatest, done. If you want to block horizontal and to the thin part of the block at the end, use a 1" by [here that would be 1" x 2" [or whatever wide] [which is really 3/4" x 1 3/4" [don't ask]]] rout a channel down the middle for the center spring, then back-cut it so it doesn't make contact with the block until it's past the angle, or, you could make it out of 2 pieces too.
Old 10-06-2003, 08:57 AM
nuno  is offline
that was one idea i had, actually, but i ended up using a... pencil! it's extremely hard to explain how i cut and placed the pencil to block the trem.
i should draw something down, if anyone's interested... but maybe Rich's method is more professional.
