Sponsor Us
About Us
Community Blog
Tech: Setup, Repairs and Mods
Body Modification
Search
Today's Posts
Registered Members don't see these ads.
Register now
it's free!
07-30-2007, 02:56 PM
courtney2018
Posts: 1,006 - iTrader: (
Body Modification
Sorry, not talking about human body modification. Talking about guitar body modification.
So anyways, many months ago I mistakely bought a 470 body, when I wanted a 570 body instead. I figured since I don't want it I'll use it as a test piece and just do all sorts of stuff to it, put a jamming paint job on it and sell it for whatever it goes for. It's all in fun anyways.
So this weekend I stripped the paint off and did some routing on the body. I have JEM/RG templates, so I did a JEM handle and routed recessed areas for the trem and electronics cavity covers. I've never had a 470 before, but apparently they skimp out on recessing stuff since it takes more time on the CNC, and of course time is money.
Also filled in the instrument jack and put in two angle jacks. One for the pickups output and the other for a piezo output if the end user wanted to install a
piezo system
. I also routed out a cavity to access the jacks from the inside.
On the backside of the lower horn I removed quite a bit of material on that backside edge so it's not a sharp edge gouging into your arm when you go to the lower frets. I have this problem sometimes with that edge gouging in. It's not like it hurts or anything. Just feels nicer with a larger radius on it.
I'm thinking of putting a battery cavity in the back incase someone wanted to use active pickups. All cavity covers will be custom cut and painted the same color as the body.
For a paint job, I was thinking of doing the whole thing in DSY and dip it with fluorescent green, pink, red, black and maybe blue...also maybe alittle bit of white.
So that's what I've done to it so far. I wanted to get some input from you all on what else you'd like to see done to it. This body will be like the ultimate modification. Also, what kind of paint job would you like to see on it?
Thanks to those that reply.
Pics....I'll get some pics up shortly so you can see what it looks like so far.
EDIT: Forgot to mention, I also routed out the trem cavity to support the
Edge Pro trem
if the end user wanted such.
Register now
it's free!
courtney2018
Find all posts by courtney2018
07-30-2007, 03:11 PM
Distantshore
Posts: 3,365 - iTrader: (
Re: Body Modification
Step away from the power tools!
J/K sounds like a fun project. Don't really have ideas
you seem to have done most of what I had in mind.
Distantshore
Find all posts by Distantshore
07-30-2007, 04:25 PM
courtney2018
I thought about recessing an area for the pickguard. And the pickups would be hard mounted to the body. What do you think about that?
courtney2018
07-30-2007, 04:46 PM
jemaholic
Posts: 2,186 - iTrader: (
Breast enlargement is one of my favs.
I also like big puffy lips on occasion.
Really long hair is a good modification too.
Tiny waists are good.
(sorry - I had to with that title)
jemaholic
Visit jemaholic's homepage!
Find all posts by jemaholic
07-30-2007, 07:53 PM
courtney2018
jemaholic
Gee, that helped out a bunch. Thanks....NOT!
courtney2018
07-30-2007, 08:17 PM
Salamander In The Sun
Posts: 874 - iTrader: (
I wouldn't route for a battery cavity unless I knew I was going to go with active pickups for sure.
Find all posts by Salamander In The Sun
07-30-2007, 09:31 PM
alex10
Posts: 696 - iTrader: (
Sounds like there isn't gunna be any wood left on this body at this rate.
alex10
Find all posts by alex10
07-30-2007, 10:02 PM
courtney2018
Like I said, this body is going to be heavily modded....just for the hell of it.
courtney2018
07-30-2007, 10:19 PM
I think you should install a Sustainer, as opposed to active pickups. A Sustainer is cooler, more practical, and it would be about the same cost.
07-30-2007, 10:22 PM
courtney2018
But I'm not going to be installing anything on it. I'm just modding the body. The end user will install whatever they like. I'd just be adding a battery cavity just in case they wanted it. If not, then it's not hurting anything by being there.
I've also thought about cutting out some slots in the body and replacing the missing material with Bloodwood or Purpleheart, but that might be going too far.
What about inlays?
courtney2018
07-30-2007, 10:29 PM
Sorry about that. I tend to get carried away fairly easily.
07-30-2007, 10:57 PM
Ki swordsman
Posts: 1,507 - iTrader: (
if people need a battery, they'll fit one in the control cavity space. but if most people don't want a battery, they might shy away from buying yours because of the wasted wood space..
personally i wouldn't put the extra piezo routing in either, you might be cutting out half your buyers cos of a simple mod..
Ki swordsman
Find all posts by Ki swordsman
07-30-2007, 11:00 PM
Are S bodies even thick enough to be able to install a battery box?
07-30-2007, 11:08 PM
courtney2018
This isn't a S body. It's a RG470.
Ok, so no battery cavity.
Binding? I've never done binding before. Not really sure it would look good with the kind of paint job I'm think of. Might end up looking like rubbish.
courtney2018
07-30-2007, 11:12 PM
courtney2018
Oh, I thought you meant an S470.
Bookmarks
Digg
del.icio.us
StumbleUpon
Google
cavity cover
edge pro trem
guitar body
jem conversion
piezo system
Ibanez PGM 30 body, Lo TRS trem, will a Lo Pro work on this body?
jem body FOR SALE sims and christopher woods
New Alder/Purpleheart/Walnut 7620 body
FS: "The Original" RG520NM, RG421, RG770 body
Exact JS body clone -- is it possible for a good luthier?
01:20 AM
