Tech: Setup, Repairs and Mods
Bolt/thread size on Edge Pro trem block side?
03-07-2005, 08:17 AM
caprile
Posts: 1,619 - iTrader: (
Hey!
Does anybody know the size of the holes on the side of the
Edge Pro trem
block? I want to put a piece of steel so it works "down only", but I have no means to measure the holes.
Thanks!
caprile
Find all posts by caprile
03-07-2005, 08:53 AM
Azrael
Posts: 403 - iTrader: (
Re: Bolt/thread size on Edge Pro trem block side?
Your gonna do a "down only mod"? Could you explain me how to? I use a backstop device for it now but it's not really *kugh* the best method to do it.
Azrael
Find all posts by Azrael
03-07-2005, 11:47 AM
caprile
Check this out:
http://www.jemsite.com/tech/img/t_trblk1.jpg
On the Edge Pro, you can put a similar piece on the other side of the
trem block
, so it's down only. The block already has the bolt holes, so all you need to do is get a rectangular piece (wood or other...I wanna try steel for mass/sustain) and screw it in!
caprile
03-07-2005, 11:50 AM
Posts: 19,354 - iTrader: (
Didn't the BRMR trem stoppers come in yet?
Dude, just take it to the hardware store!
03-07-2005, 11:55 AM
Azrael
I only have an Lo-
Pro Edge trem
.....not an Edge Pro...any idea how to do it on a Lo-pro?
Azrael
03-07-2005, 11:57 AM
caprile
Hardware stores suck big time here!
I still haven't found the screw insert for your EP mod...the clerks at a specialized screw store didn't know what the hell they were...and I showed them a picture!
caprile
03-07-2005, 12:01 PM
Same thing here on the set screws, but, the EP screws ARE just screws
edge pro trem
edge trem
pro edge
pro edge trem
trem block
what is the proper diameter and thread pitch for ibanez s whammy bar
will edge zero pro fit edge 3 route?
what trem is on the rusty cooley
Angling the trem, bass side higher, causing problems?
DoctorCrunch
05:47 PM
Lo-Pro Edge Trem Level? - Does the trem need to be level wit
Dean Southcombe
10:09 PM
01:58 PM
