Old 02-06-2001, 12:14 AM
ruby  is offline
Posts: 9  -  iTrader: (0)
Boss DD-3 problems - no delay
I recently dug out my Boss Digital Delay DD-3 pedal and began to mess around with it again. Then I noticed a slight problem. There was no delay. The red indicator light came on and sound came through my amp but no delay. It is turning on and I have checked and all of the saudering is still intact so I need help. Has anyone had a similar problem? Could I send it in to Roland to fix? Around how much would it cost? Thanx for all of your help.
Old 02-06-2001, 03:05 AM
J Todd Beachler  is offline
Posts: 248  -  iTrader: (0)
Boss DD-3 problems
Um, call Roland.
Old 02-06-2001, 07:31 AM
Josh Blagg  is offline
Posts: 340  -  iTrader: (0)
Boss DD-3 problems
Is the battery new? *I put an old battery in a delay one time and the delay was very faint. *If not, I have heard where "no delay" can be a problem. *Your best bet is Roland like the dude said. *If they don't help you, take a look at it internally if you know anything about electronics. *There could be a loose connection.
Old 02-10-2001, 10:59 AM
alienx  is offline
Posts: 191  -  iTrader: (0)
Boss DD-3 problems
No delay, use TWA, they always have some in stock. :biggrin:
Well, I agree check the battery first. If that shouldn't help, check the knobs, it may got stuck at a low delay rate. And if that should not help, disassamble it and check for loose connections.
Good luck!
boss digital delay
