Tech: Setup, Repairs and Mods
Buzzing on the first fret - How can I fix it
01-27-2002, 03:21 PM
Vai the god of Sound
Posts: 232 - iTrader: (
On the new Jem that I'm buying, it has buzzing on all of the strings on the first fret.
I haven't been able to adjust anything yet because it isn't mine (yet). But I've looked at a few factors such as action,
truss rod adjustment
, and fret dressing... and even raising the nut a bit.
Will any of these work?
Visit Vai the god of Sound's homepage!
Find all posts by Vai the god of Sound
01-27-2002, 08:13 PM
ScottB
Posts: 2,208 - iTrader: (
You need to answer a few questions first:
1.) By "new" Jem, do you mean new from a
music store
, or used or second hand , but "new" to you only. If you're buying a brand new Jem from an authorized
Ibanez dealer
, they should do a proper setup and remove any buzzing before you accept it.
2.) If the buzzing only occurs when you fret the strings at the first fret, your problem is most likely a high second fret which the strings are buzzing against. If this is the case, changing the nut height won't help because once you fret a string, the nut is out of the vibration path. The second fret needs to be lowered and level with the others.
3.) If the buzzing occurs with the strings in the open position, and they are hitting at the first fret, a nut shim could help.
ScottB
Visit ScottB's homepage!
Find all posts by ScottB
01-27-2002, 10:54 PM
Two hands31
Posts: 4,989 - iTrader: (
I agree, hopefully a good setup should help. *And the
guitar shop
should do that for you. *
Two hands31
Visit Two hands31's homepage!
Find all posts by Two hands31
01-27-2002, 11:32 PM
sorry, I should't have said new...
I got the same suggestion as to shim the nut...how do I do this?
01-28-2002, 04:09 PM
AC1Chuck
Posts: 11 - iTrader: (
Actually I popped in here to drop the same topic..
For me, its the second fret. *First on my blue flake RG570, now on my JEM7VWH, theres a small indent forming below the G and B strings on the fret itself. *I'm just a hobby player and am not sick enough to do fret dressing myself... I was wondering if other guys and gals have the same problem or am I just too hard on the strings?
Thanks all-
Chuck
AC1Chuck
Find all posts by AC1Chuck
01-28-2002, 04:45 PM
Project Guitar
Posts: 979 - iTrader: (
A little about
Neck Shim
's
Here
Project Guitar
Visit Project Guitar's homepage!
Find all posts by Project Guitar
02-09-2002, 01:31 AM
kcuhc91270
Posts: 3 - iTrader: (
I have the same prob on my rg7620mostly on the g and a little on the dbut this may sound odd ,but the b seems tovibrate differently when the locks are tight in the middle of the nut was grinded a little by a tech to keep the strings touching the channelthere is another prob when I fret higher on the b it buzzesnear the second fret I thinkannoying mostly but the buzz when it is open and locked down comes thru the amp sounds like crap too and I understand when tuned down a half step the lower the action = more buzz the action on all strings is good and the others sound fine I was thinking about getting a new nut and some small shims what do you think???????
kcuhc91270
Find all posts by kcuhc91270
02-09-2002, 02:45 AM
littlegreenman
Posts: 2,626 - iTrader: (
If it's only buzzing on the first fret (open strings) then all you need is to shim the
lock nut
up a little tiny bit, like maybe .010" to .015". *it's just sitting a little low and your strings are buzzing off the first fret. *If when you fret the first fret, you are still getting a buzz, then you may need to either raise the action at the bridge, or loosen your
truss rod
off a little bit. *I don't see the need for a neck shim really, just a nut shim, or a neck adjustment or bridge adjustment.
littlegreenman
Visit littlegreenman's homepage!
Find all posts by littlegreenman
02-09-2002, 02:55 AM
kcuhc91270
loosening does that mean straightening =tightening or put more bow on it
kcuhc91270
02-09-2002, 02:22 PM
littlegreenman
To tighten the truss rod would put more back bow into it, or, like tightening a bolt, it puts more tension in. *Loosening means to turn counter clockwise, or like undoing a bolt, this allows the
string tension
to pull the neck forward, or, flatten the neck,or increase the front bow. *
littlegreenman
02-09-2002, 03:30 PM
kcuhc91270
thanks I'll give it a shot.
kcuhc91270
guitar shop
ibanez dealer
lock nut
music store
neck shim
nut height
nut shim
rod adjustment
string tension
truss rod
g string is buzzing
how to fix fret board separation
warmoth 24 fret?
neck what your low action jackson "24th fret"
how to fret level
07:49 AM
