Old 07-14-2005, 02:18 AM
gunkungfu  is offline
Posts: 405  -  iTrader: (11)
Smile
can a orginal edge replace newer lo pro trs trem
want to replace the bridge on my rgt42 which is a lo pro with a orginal edge will it fit without mods
Old 07-14-2005, 04:40 AM
Dylan7620  is offline
Posts: 636  -  iTrader: (1)
Re: can a orginal edge replace newer lo pro trs trem
edge trems for the most part can't just slip in there without some modding. but i think an OFR can.
Old 07-14-2005, 04:57 AM
rory  is offline
Posts: 102  -  iTrader: (0)
Dylan is right, only rarely will an Edge/Lo-Pro fit in a TRS cavity without routing to allow for the longer wings. An OFR is a direct retrofit, but it will look out-of-place because the treble wing is wider than the bass wing. The licenced Floyd made by Gotoh (who makes the Edge/Lo-Pro/EP trems) is just as good, will retrofit and won't look out-of-place.
Old 07-14-2005, 07:02 AM
LonePhantom  is offline
Posts: 5,369  -  iTrader: (6)
Reviews: 98
I say yay on the Gotoh licenced Floyd. I picked one up for my project guitar which is currently being built and I've put it on my RG470 for the time being until the guitar is built and it's a fantastic trem.
The only thing you'll need to look out for is the trem block. I "think" there are two different sizes for the trem block on the trem. The longer one wont quite fit in the cavity with the backplate on unless you have high action. I've just got the back plate off for the time being, and the body being built for my new axe will be thicker so it will have no problem fitting.
If there is only one size trem block on the trem just shorten it a bit if you don't want it hanging out the back.
Old 07-14-2005, 12:31 PM
Thanks for the info
edge trem, edge trems, trem block
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma JEM and Universe Guitars 89 06-18-2007 11:57 AM
Weird clunky edge trem, help please. track7 Tech: Setup, Repairs and Mods 24 07-26-2002 04:26 PM
Can't get edge trem in adjustment - always too high, too low bduersch Tech: Setup, Repairs and Mods 4 11-19-2001 12:37 AM
