can i move my input jack - Jemsite
Old 01-12-2011, 09:30 PM
rg_man 1993  is offline
Posts: 135  -  iTrader: (0)
I have a mid 90s rg and i want to move the input jack so its more like a jem js or pgm guitar. can i do that?
Old 01-12-2011, 09:59 PM
fwd0120  is offline
Posts: 2,876  -  iTrader: (0)
Reviews: 4
Re: can i move my input jack
You can do that, it takes some drilling and re-wiring, just search around the forum some, I'm sure somebody has done it, and there may be an accurate spec on it.
Old 01-12-2011, 10:25 PM
TMatt142  is offline
Posts: 675  -  iTrader: (6)
I did it to my RG7620...Just go to projectguitar.com. They've got a tutorial on it....Can't remember, but you'll need a half inch dowel to fill in the old location, should slide right in there. Ya might want to set up some sort of jig to drill it, I did mine free hand and it wasn't too bad...
doing it free hand gave me a kind of sloppy outside edge but with a little filler and some sanding, it turned out just fine
Old 01-12-2011, 10:44 PM
fwd0120  is offline
Reviews: 4
I believe the is a slight bevel'radius to it as well, the input jack should also be recessed slightly too i believe, but i'm not sure how much.
Old 01-12-2011, 11:48 PM
AlaskaBat  is offline
Posts: 9,291  -  iTrader: (18)
Reviews: 98
No---it's against Ibanez policy to modify any of their products---you'll go to jail! Bwaaaaaah haaaaaaa haaaaaaa!
Here's the tutorial link:
http://projectguitar.com/tut/output.htm
Old 01-12-2011, 11:58 PM
TMatt142  is offline
You can recess it as much as you want really (but not too much!). I went deeper than the standard Jems go....
Old 01-13-2011, 01:20 AM
RGTFanatic  is offline
Posts: 10,114  -  iTrader: (24)
which series do you have.......RG2xx,3xx,4xx,etc??
The input jack is different on the RG4xx series and lower. The project is the same, but the process is slightly different.
I'm actually doing this mod on my RG450 right now. I have some pics I can post, but the job is not finished yet............
Ryc
ibanez rg , input jack , jem , js series , pgm
Input jack, Help please fwd0120 Other Ibanez Guitars (including Premiums) 2 04-09-2010 05:00 AM
Jem input jack freedom's door Tech: Setup, Repairs and Mods 2 05-26-2005 11:24 PM
cable/guitar jack pretty much falls out of the input jack musichopper Tech: Setup, Repairs and Mods 5 10-09-2004 12:29 PM
JS CG Input Jack 7 Dying Trees JS (Satriani Model) Ibanez Guitars 8 08-28-2002 07:48 AM
Powered by
