Tech: Setup, Repairs and Mods
Can I use Edge posts with an Edge Pro??
10-25-2006, 08:25 PM
PatrickSimsCustomShopUSA
Posts: 1,166 - iTrader: (
I bought an edge pro and tried putting it on my guitar using edge posts and I can't get it set up right. Do you have to use the edge pro posts with the edge pro? Does anyone know what the differences are between teh edge pro posts and the edge posts?
Any help would be greatly appreciated.
Thanks!
Find all posts by PatrickSimsCustomShopUSA
10-25-2006, 09:09 PM
Posts: 19,344 - iTrader: (
Re: Can I use Edge posts with an Edge Pro??
The only difference in the studs is the set screw and Allen size.
10-25-2006, 09:21 PM
crevis
Posts: 2,599 - iTrader: (
The EP probably has different knife edges to the origanl trem.
crevis
Find all posts by crevis
10-25-2006, 09:26 PM
The knives are all the same, ED / LP / EP. [ED and first couple years LP knives didn't have the press fit detent that keeps them tight in the base, otherwise they're identical except for how fat each run is]
10-25-2006, 09:54 PM
So what your saying is the edge posts ought to work fine with the edge pro Rich?
10-25-2006, 10:11 PM
Absolutely.
10-26-2006, 07:32 AM
marianozz
Posts: 2,221 - iTrader: (
Is it an old body, routed for a edge / lo pro? Then it could be the route spacing...
marianozz
Find all posts by marianozz
10-26-2006, 07:35 AM
no, its a brand new prestige body. I'm using an edge pro in it but I didn't have the posts, so I through in some edge posts. After setting it up the back end of the tremelo is real high so I screwed in the springs some and its still a little high so I thought it may have something to do with the posts, but according to Rich its not so it must be the springs so I'm going to replace them.
10-26-2006, 11:00 AM
marianozz
Cool, good luck
marianozz
will edge zero pro fit edge 3 route?
how to set up a edge 3?
is my edge trem bar in all the way
I just put an Edge in my RG470!
DirtyBird31
12:22 AM
Need to replace original Edge trem posts ... many questions.
JohnnyRasgueado
12:34 PM
Edge trem with trs type posts
stratman219
09:03 AM
TRS posts vs Edge posts - Difference in size, position?
YngVaiTriani
10:36 PM
Tremolo Posts - Edge series vs TRS series
YngVaiTriani
09:52 PM
04:19 AM
