Old 01-13-2002, 12:01 PM
johank  is offline
Posts: 95  -  iTrader: (0)
changing pickups
I have an Ibanez RG507, which i'm planning to change microphones on.
The ones that are installed now, are the factory installed ones.
My Questions are:
how much difference in the sound will I get if I change to a pair of evolutions.
Will it be a huge difference, will it be worth the money?
Is it difficult to install the pickups?
Old 01-13-2002, 07:58 PM
6828  is offline
Posts: 200  -  iTrader: (0)
changing pickups
My advice is to go to your local music store and do two things.
1. Ask how much it costs for a pickup installation if you buy the pickup through them. It might be free, or cheap enough that you dont have to worry about installing it yourself.
2. Play a similar guitar to yours with the pickup your interested in. Then play through the same system with your guitar and listen to the difference. (This is a very rough guide but might give you a better idea of which direction to head in).
Installing a pickup can be simple, or hard depending on your experience with soldering and electronics. Sometimes the best way to learn something is to try it yourself. Getting new pickups can make a very big difference if the pickups you have are weak and you want a bigger sound. Some factory pickups are great, it's a matter of personal taste and style.
Hope this helps.
Regards,
Tony
Old 01-16-2002, 03:12 AM
Mr Orange  is offline
Posts: 448  -  iTrader: (0)
changing pickups
I had an RG507, and I got rid of the stock pus and never looked back.
I tried an Evo bridge and an Air Norton neck. Air Norton worked good, but Evolution was a bit cold sounding on that guitar. *I'd perhaps recommend Duncan '59 and Jazz.
air norton, air norton neck, evo bridge, local music store, music store, norton neck, pickup installation
