Go Back   Jemsite > Toolbox: Setup, Repairs and Mods > Tech: Setup, Repairs and Mods
Old 09-13-2002, 09:03 AM
track7 track7 is offline
Posts: 604  -  iTrader: (0)
Changing string gauge on my 7vwh?
Hello...
I'mv wanting to switch from 9's to 10's on my jem7vwh. What tricks of the trade do you all recommend for making it a pianless process??
Would i need an extra spring, adjust the trem angle, mess with the truss rod??
Help would be greatly appreciated!
Thanks In advance
Track7
Old 09-13-2002, 01:06 PM
pri0531 pri0531 is offline
Posts: 1,477  -  iTrader: (0)
I have had tens on my VWH for about 4 years now. You will have to tighten the springs/adjust the trem angle a good bit, but another spring is not needed. As far as the truss rod I did adjust mine a little bit. I would go ahead and change the strings and adjust the trem angle and play it for a couple of days and let it settle. Then you can see if you need to adjust the truss rod.
Out,
GP
PS.: The VWH sounds great with .10s!!!! I use DAddario EXL110 XL.
Old 09-13-2002, 02:08 PM
Rich Rich is offline
Posts: 18,373  -  iTrader: (18)
I always go with 4 sprigs, just a personal preference.
Old 09-13-2002, 04:34 PM
thanks for the replies...
how would i know if the truss rodd needed doing or not, and how do I go about it if it does? Truss rods have always been my grey area
I think i'll try the 4 springs, and whatever trem angle adjust needs..
Should I change one string at a time or take the all off...normally i would just change one at a time...but being as the extra tension and spring has to be accounted for i'm unsure,
help again please!?
thanks
track7
Old 09-13-2002, 04:42 PM
I change one string at a time. Don't be scared when the trem is pointing to the sky. Gradually tighten the springs as you go.
Out,
GP
Bookmarks
addario exl, truss rod, truss rods
