Old 10-23-2005, 05:29 AM
ZenekZelman  is offline
Posts: 2  -  iTrader: (0)
Changing string gauge questions
Hi!
I want to change string gauge in my guitar from 009-042 to 010-046. I've got few questions about this change:
1. If there will be more neck bow (i.e. now i have 0,3mm at 7 fret, would it be more i.e. 0,5mm?) after changing string gauge, or less neck bow (0,3mm-0,1mm?)?
2. Should i must change action after changing string gauge?
3. Should i must change intonation after changing string gauge?
My guitar is equipped with Lo Pro Edge.
Old 10-23-2005, 06:47 AM
Algiman  is offline
Posts: 2,553  -  iTrader: (14)
Re: Changing string gauge questions
1 and 2 will depend on how you like your guitars set up but yes, both will need some adjustment.
3. You'll need to correct the intonation a little.
Also, you will need to increase the spring tension.
Old 10-23-2005, 06:50 AM
OK Thanx !
Old 10-23-2005, 12:00 PM
Ekim  is offline
Posts: 1,486  -  iTrader: (1)
Reviews: 4
How can you find out if a certain gauge is too big for the guitar? I was wanting to experiment and put some 12s on one of my JS's. I don't want to warp the neck or anything.
Old 10-24-2005, 02:45 AM
lyconxero  is offline
Posts: 1,469  -  iTrader: (0)
I have an RG7321 with D'addario 10s on it and I want to tune it a step down. What strings would someone suggest? I like the feel and tension of 10s in standard tuning and would like that same tension or maybe slightly less a step down but not more. 7 string guitar strings seem to be pretty limited in that I can't find very many choices out there.
neck bow, pro edge
7 String gauge question.... nosferatu123 Other 7-string Guitars 31 03-19-2011 02:01 PM
Yet another poorly mixed song by your truly IbanezroadstarII Multimedia: Music, Pictures & Sounds 33 03-16-2006 10:01 PM
what do you think .009-.042 with a low .058 string gauge JN777 Other 7-string Guitars 0 01-15-2005 11:31 AM
7th string Gauge JN777 Other 7-string Guitars 13 02-21-2004 07:54 PM
Changing string gauge on my 7vwh? track7 Tech: Setup, Repairs and Mods 4 09-13-2002 04:42 PM
