Old 12-02-2006, 11:53 PM
count_dissident  is offline
Posts: 2  -  iTrader: (0)
Changing String Gauges...
When changing string gauges from a D'addario EXL110 7 string set(010 013 017 026 036 046 056) to a Dean Markley LTHB set(.010 .013 .017 .030 .042 .052 .060) will a truss rod adjustment be needed(or likely) to compensate for the tension on a 25.5 scale neck that is tuned down 1/2 step? I realize a bridge adjustment would need to be made for a floyd rose,but I wasn't sure about the truss rod.
Thanks
-Count
Old 12-03-2006, 12:02 AM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
Re: Changing String Gauges...
Slight truss adjustments are needed regardless!
It's a constant battle
Old 12-03-2006, 12:10 AM
OLIE_ROCKS_THE_80'S  is offline
Posts: 2,770  -  iTrader: (5)
Reviews: 10
Lightbulb
That is true although most of the time all you have you have to adjust is the trem angle, which has to sit parallel to the surface of the guitar body when set up correctly and with the proper amount of tension!
addario exl, dean markley, floyd rose, guitar body, rod adjustment, string gauges, truss rod, truss rod adjustment
longer string life? jeffrg270 Tech: Setup, Repairs and Mods 19 11-27-2006 02:16 AM
Help: low string goes abnormally sharp when picked Fretmelter Tech: Setup, Repairs and Mods 5 05-22-2006 03:16 AM
Carvin technique Kontalonis Other 6-string Guitars (non-Ibanez brand) 17 04-24-2006 09:41 PM
String Changing, ARGH! klp2332 JEM and Universe Guitars 4 07-09-2005 11:35 PM
7th string help JN777 JEM and Universe Guitars 8 02-07-2004 11:22 AM
