Old 11-07-2006, 08:28 AM
rone12  is offline
Posts: 9  -  iTrader: (0)
clicking sound on my ibby....
hi guys, im a newbie here...this is my first post...
recently i removed my trem on my ibby rg because it needs cleaning....
i followed the instructions on the ibanez rules web site on how to remove the trem, after i placed the trem again and plugged it in my amp... i can here a clicking sound after i dive bombed....it was not there before when i removed the trem... the trem is only trs mij...can someone tell me where did i go wrong? thanks in advance guys...
Old 11-07-2006, 09:30 AM
crevis  is offline
Posts: 2,599  -  iTrader: (1)
Re: clicking sound on my ibby....
It could be the springs moving around, or the strings hitting the pickups, could be anything really. Mute the springs at the back while diving and see if it goes away.
Old 11-07-2006, 11:31 PM
rone12  is offline
ok....i'll try it as soon as i get home from work....thanks crevis...
Old 11-09-2006, 08:35 AM
rone12  is offline
hi guys! ive checked the springs of the trem...its not the springs or the strings that causes the clicking sound..
ive tried to loose the strings and tried dive bombing the trem again while the strings are loose..this time the clicking sound was gone... i re-tuned the strings and there was the clicking sound again!!
i think the clicking is not trem related...
when i dive bomb,i can feel a little vibration at the neck when it clicks...
ive also checked the trust rod,and everything seems to be ok....
need help in this guys..
thanks!!!!!
Old 11-09-2006, 09:54 AM
GTR-MAN  is offline
Posts: 1,056  -  iTrader: (0)
Images: 8
I had that problem once on my VWH. It was before I learned how to set up a floating and trem and ended up being the reason I learned how to set them up. I took it to a "supposed" pro to have it set up. I get it back and I got a "click" when I dove or raised the bar. It also would go sharp or flat. Of course I was upset, and after examining the guitar I saw that the bozo who set it up had one of the saddles so far forward that it was catching on the pickguard. I was pissed off, but instead of taking it back to have the re-do it I decided I didn't want them to touch my guitar again and learned how to do it myself.
Old 11-09-2006, 11:12 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
it happens when you don't tighten the saddle screw enough, then when you tune, the string would drag the saddle toward the neck. this can happen while you're setting up a guitar, but you (pro) are supposed at least to take a look and give it a try before bring the guitar back to the customer...
Old 11-10-2006, 07:49 AM
rone12  is offline
thanks for the replies guys...i'll check it again and i'll keep you guys posted....
Old 11-14-2006, 07:32 AM
rone12  is offline
guys i've checked if the pickguard is making contact with the trem and its not.....
anymore ideas??
Old 11-14-2006, 09:21 AM
nuno  is offline
you said the click comes from the neck, not from the trem, right? have you disassembled the neck too for cleaning?
Old 11-14-2006, 02:54 PM
TommyGuitar  is offline
Posts: 206  -  iTrader: (0)
Your neck screws aren't tight enough.
Old 11-14-2006, 05:33 PM
LonePhantom  is offline
Posts: 5,368  -  iTrader: (6)
Reviews: 98
Yeah tighten up neck screws, this causes a "clicking" noise when using the trem.
Old 11-16-2006, 01:08 AM
rone12  is offline
neck screws can be found at the upper back of the body of the guitar,right guys? sorry for the stupid question...
Old 11-16-2006, 01:20 AM
The Euphor  is offline
Posts: 2,948  -  iTrader: (4)
Correct, four of them in total. Big screws.
Old 11-16-2006, 01:43 AM
rone12  is offline
ok thanks euphor...
Old 01-03-2007, 01:44 AM
rone12  is offline
update on my guitar...i took it to a tech.....and he examined it...it turns out that the shim on the neck was not properly placed....so he fixed it....
no more clicking sound...
locking nut, neck screws
Multi track recorder or PC with interface? Ant1981 Recording Studio 68 04-07-2006 12:20 PM
Not clear sound from the low strings in my JEM7V corinos Tech: Setup, Repairs and Mods 5 01-12-2006 10:08 AM
Any of you do/wanna do music and sound for Games??? dreaming_neon_black Off-topic / Miscellaneous 5 10-29-2005 03:27 AM
Distortion sound : V-AMP(2) or LINE 6 POD (XT) JEAPSON Gear and Equipment 13 08-08-2003 04:08 PM
Please help me dial in a good sound... craig Gear and Equipment 2 08-29-2001 02:29 PM
