Old 06-25-2005, 01:24 PM
Acid Rain  is offline
Posts: 34  -  iTrader: (0)
Coil Tap!!
Hi there,
I've finally got my schematics etc and about the install my DiMarzios, BUT I wanted to coil tap all my pickups (especially my bridge humbucker). So I can't use one SPDT Mini switch for all three pickups (H/S/S - technically H/H/H) but I found this for One Mini toggle:
http://www.stewmac.com/freeinfo/pickups/dimarzio.html
I understand the coil cut, but my SPDT is On/On. How can I set it up to be OFF/ON? Or does the website mean - On (humbucker)/On (coil Tap)
Thanks!
Regrads
Sim
Old 06-26-2005, 12:52 AM
frankfalbo  is offline
Re: Coil Tap!!
Yes, that's what it means. You could use either an On/On or On/Off depending on how you set it.
You can do all three pickups with a SPDT if you simply use the other side of your 5-way switch to route the coil junction wires to the SPDT. If that doesn't make sense to you, then just continue what you're doing and forget I said anything.
Old 06-27-2005, 09:12 AM
riskordie  is offline
Posts: 25  -  iTrader: (0)
Re: Coil Tap!!
can some1 post a schematic on coil tapping for a HSH guitar?
I dont really understand the diagrams from stewmac
and is it possible to do on a stock pup selector or do i need to get a superswitch?
Cheers
Old 06-27-2005, 11:16 AM
Re: Coil Tap!!
It's possible to do it on a 5 way switch but i wouldn't be sure ~ frank might be able to tell you. But there are number of ways but If you don't want to use a mini toggle switch there's always using a Push Pull pot and wiring it that way. The Stewmac diagram shows you a SPDT from below so your seeing the connectors of the switch. You then connect the wires to the connection points. I'll try and find you a schematic, I think Seymour Duncan have loads inc. Coil taps
Old 06-28-2005, 02:19 PM
Re: Coil Tap!!
one last thing - on - http://www.stewmac.com/freeinfo/pickups/dimarzio.html
With the coil cut, how do I know which coil to cut off. Does the image show the south coil getting cut off or the North coil?! Help?!
Thanks
Old 06-30-2005, 07:41 AM
Re: Coil Tap!!
Frank: Just noticed, that when I wired my pickups with no humbucker mods the wires that are need to coil tap are connected to the tone pots etc. So does that mean I need to add extra wire from the 5 way switch to the coil tap?? Thanks!
Old 06-30-2005, 08:27 PM
Re: Coil Tap!!
Acutally I understand the coil tap diagram now, but the thing is that Green is connected to one leg of the tone pot and red and some other wires are connected to the 5 way switch and black + white is connected to the DPDT unlike the one I found off DiMarzio.com?
Here's one I found off Jemsite: http://www.jemsite.com/tech/img/t_wd_7ct2.gif
Does this diagram acutally work for a H/H/H wiring with Coil tap?
Old 06-30-2005, 08:50 PM
Re: Coil Tap!!
Green shouldn't be connected to any "leg" of the tone control, just ground. The jemsite diagram is fine, but only if you wanted to add a second switch. If you wanted to keep that switch, you'd have to route the neck and bridge coil taps through the unused half of the 5-way switch, so that those were sharing the same side of the DPDT. Positions 1 and 2 would feed the neck coil junction to the switch, and positions 4 and 5 would feed the bridge coil tap to it.
Old 07-01-2005, 06:18 AM
Re: Coil Tap!!
Woah..you've lost me! What do you mean by if I want to keep that switch? I'll be installing the DPDT though? hmm.. I can't understab the part were you stated, where I need NECK and BRIDGE wires to go to the used part of the diagram?? If you look at this: (found off another website) - www.artificial-infection.co.uk/wiring.gif
OHHHHHHHHHHHHHHHHHHHHHHHHHHHHH! Hang on, the Jemsite diagram shows one half of the 5 way switch right? But the OTHER half of the 5 way switch isn't used at all. So wires from neck and bridge need to copied from the original half to the Unused half of the switch. Therfore the unused side of the switch is on the same side as the DPDT switch, therfore, it's easy to place wires on the DPDT? Is that right? How would I go about doing that on the above diagram (www.artificial-infection.co.uk/wiring.gif) though as both sides are used? Would it be possible for you to add/draw the DPDT in for me?
Or would it actually be simplier to use two DPDT switches, and use one hald of the DPDT for the BRIDGE, and then the other DPDT for the neck?? Wouldn't that be slightly easier as both halves of the 5 way switch are used???
Thanks frank!! please help! thanks!
Old 07-01-2005, 06:26 AM
Dr. Funkenstein  is offline
Posts: 115  -  iTrader: (0)
Re: Coil Tap!!
Not a help with the wiring, but using 2 DPDT switches gives you the option of keeping your humbuckers in different states without the hassle of switching all the time mid song, i.e. humbucking bridge with single coil mode neck.
Regards,
Dave
Old 07-01-2005, 03:01 PM
Re: Coil Tap!!
The problem is that the "artificial-infection" diagram is for a totally different switch, and it is automatically coil tapping the pickups in the in between positions. There's not much reson to add a coil tap switch to that diagram, unless you wanted single coil options in the two outside positions. So, which switch do you have? Is it like the Jemsite diagram or the A-I diagram? What do you want the 5-way switch to do? simply switch pickups? Or do you want some automatic coil cutting to happen during the in-between positions?
It seems to me the easiest way to do this is with the Jemsite diagram AND that switch. You run the middle pickup coil junction right to one side of the DPDT, and the outside pickups' coil junction to the corresponding lug on the unused portion of the 5 way. Then you bring the "hot" of the previously unused side of the 5 way over to the other side of the DPDT. That way when you're bridge or neck pickup is on, the corresponding coil junction is also going to the coil cut switch.
You can also take a picture of everything you have, and your current wiring and then I can tell you exactly what to do.
Old 07-01-2005, 09:56 PM
Re: Coil Tap!!
Hey frank, - The 5 way switch in that aritificial-infection diagram is what I believe to have.
My strat (S/S/S) is wired with 5 way -
1. Series Neck (sinlge)
2. Parallel Neck + Middle
3. Middle
4. Parallel Bridge + Middle
5. Middle
Right now I'm going to install my (H/S/S - technicall H/H/H) pickups and want to achieve the same setup (Positions 2 & 4 cut into parallel). So I searched and found that wiring diagram which technically, suits my needs. I didn't know the JEMSITE diagram had a different 5 way by the way! So the A-I diagram, 5 way is what I want. I would take pictures but I can't right now, as my guitar still needs to be used until a few days! so It won't be long.
All I want my DPDT is to coil tap the neck and bridge, and seeing I have another DPDT, I could potentially coil tap the middle but doubt it. I want the DPDT to just have simple coil switching modes - On (humbucker)/ On (coil Tap).
Any ideas? I can take pictures maybe tomorrow, as it's quite late now, but if you can help many thanks!
Old 07-02-2005, 07:08 PM
Re: Coil Tap!!
Arghhh ****e... I tell a lie - I actually have this 5-way switch:
http://www.fender.com/support/diagra...134600DPg2.pdf
So I have no I idea which diagram!!! Please help!!
Here are some more Pictures: (I asked A-I if he could host these for me)
www.artificial-infection.co.uk/switch.JPG
www.artificial-infection.co.uk/switch2.JPG
www.artificial-infection.co.uk/body.JPG
Oh and do you know what these three little Holes are for?!? Never seen them on other strats, but thats new. They're not for my DPDT switches are they? If so, there aren't any holes for wires to go through and the two outside ones are slightly smale but the middle is big enough for the DPDT to go into! Any ideas
Thanks!
Old 07-04-2005, 03:37 PM
Re: Coil Tap!!
Help..??
Old 07-05-2005, 03:08 PM
Re: Coil Tap!!
I don't really have time to do a diagram or anything. The switch you have is standard, and comprised of two halves. Each half contains pins 1,2,3, and a constant hot. Just wire one half of the switch with each pickup going to the appropriate tab, and the other half of the switch will be unused. Then take the bridge and neck pickup coil junctions (b/w) and wire one to each side of the DPDT, you'll have a coil tap that works only on those two pickups. If you want to coil cut all three pickups, then use the other half of the 5-way. Wire the coil junctions of the bridge and neck ONLY to the corresponding pins on the other half of the switch, and wire the constant to one side of the DPDT. That way when the bridge or neck pickup is on, the coil cut wires will feed the DPDT. The other side of the DPDT is now free to accept the middle pickup's junction wires.
If this isn't making sense then I'd say you have to go to a tech, or start reading more about the inner workings of the components and why/how they do what they do. Good luck,
Single coil sized pickup similar to an Air Norton? Kindred_Spirits Pickups & wiring 4 05-10-2005 11:43 AM
7 strings, 2 hum + single coil ... i need an EMG solution! skattabrain Pickups & wiring 0 11-01-2004 10:53 PM
Coil Tap vs. Out-of-Phase Switching horstausmforst Pickups & wiring 10 07-14-2004 05:40 PM
Replacement Single Coil for BFP? Dunadan Pickups & wiring 6 07-05-2004 12:22 AM
Wiring my 520 w/ a 3-way & coil tap... NickFlyMan Pickups & wiring 1 01-28-2003 06:46 AM
