Old 06-22-2008, 05:06 PM
-Rhaab  is offline
Posts: 479  -  iTrader: (0)
Could an oil finished guitar
like the s5470sol be refinished, like a solid color.
Old 06-22-2008, 06:35 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Re: Could an oil finished guitar
Yes...
Old 06-22-2008, 06:49 PM
marianozz  is offline
Posts: 2,221  -  iTrader: (20)
I dont know, ive read that once you oil a piece of wood, it kinda prevents paint from adhering to it properly in the future...
i guess with enough sanding you could get rid of the oil, but, on an S body that may be way too much sanding!
Old 06-22-2008, 06:58 PM
syxxstring  is offline
Posts: 156  -  iTrader: (1)
Yes, you would probably want to use a primer and sealer system.
Primers would create adhesion and give you a straight and level surface after sanding. The sealer would bond to the primer and lock anything from creeping up through primer and effecting the paint above.
Depending on the color you want you can tint the sealer and clear.
For a flat surface many sealers are hardend and do not require a clear coat.
Your mileage may vary, this is based on the training in custom paints I have gotten from House Of Kolor. Other paint systems may vary in application.
FS: Ibanez JS6 oil finished JS hardtail zoner Classified Ads: Guitars and Gear 1 06-28-2006 06:05 PM
Tung Oil or Danish Oil? Steve_Vai_777 Tech: Setup, Repairs and Mods 4 09-06-2005 06:05 PM
..just finished my instrumental guitar demo GonWild Multimedia: Music, Pictures & Sounds 0 09-21-2004 11:22 AM
Tung oil/Teak oil refinish question... Jupiter Tech: Setup, Repairs and Mods 15 10-04-2002 05:45 PM
Does Rem Oil = Bore Oil?? - Just bought some at Wally World trouble311 Tech: Setup, Repairs and Mods 2 02-10-2002 08:14 PM
