Old 11-22-2006, 09:34 AM
ashbass  is offline
Posts: 372  -  iTrader: (9)
Crazy man neck mod
Here's a risky one I just finished. I got a nice red 540R body from Frank Falbo a while back and needed a neck. I've some other 540Rs with the original style necks for those guitars but wanted something slicker for this one. In my parts bin there was an early 90s S series wizard neck that felt pretty good as it was thicker than the typical wizard of that time and not as wide. But the frets are very worn and it buzzes like crazy, so no go. I had a red heastock wizard as well with a repaired crack behind the nut that wasn't going anywhere so I cut off the last two frets and put that on. It had one buzzy fret and was comfortably thick with a nice U shape but was way more narrow than any wizard I've ever held. The nut hung over the neck on both sides. So it was just going to be a temp neck. The red headstock didnt' match the red of the guitar anyway.
So then I get a '92 wizard in with a large V finish crack behind the nut. This one has no buzz and I was waffling on using it. It was wider than the red-head which was good, but still a little too wide across the fretboard. Some wizards are like a V shape were at the top of the V they are just too wide for my comfort. Back and forth I think, cut off those last frets? Wait for another neck? Cut off those frets? Wait?
I cut them off. Still...
Here's the low-tech part of the show:
I figured that I'd try to roll the shoulders a little to lessen that V and make the fingerboard more comfortable. I got a mini-screwdriver and rubbed the shaft of it back and forth between the frets on the edge of the board. It worked but was tricky to get the same amount of roll between each fret. So it feels better now when fretting and playing but the fret ends were jabbing into my hand when I moved around. Can't have that. But how to fix? I could take the guitar to a luthier so the frets could be filed back, OR, do a poor man's luthier job myself. I went with the poor man's job and if you didnt' cringe about the screwdriver shaft, you probably will now.
I got some 120 grit sandpaper and wrapped it around an old rg neckplate and went to work sanding the edges of those frets by running the sand paper up and down the length of the neck. I'm almost embarrassed thinking about how low tech I must have looked. It worked beatifully though and also rounded the fretboard edges a little more than the screwdriver shaft had done. The neck is amazing now and fits my hand perfectly with no ouch as I move around.
That guitar handles like a ferrari now. Zoom zoom!
Old 11-22-2006, 09:40 AM
The Euphor  is offline
Posts: 2,948  -  iTrader: (4)
Re: Crazy man neck mod
Pics?
Old 11-22-2006, 11:41 PM
quik  is offline
Posts: 494  -  iTrader: (0)
Interesting post. You are fearless. Now, how about some scalloping?
Old 11-22-2006, 11:52 PM
j.arledge  is offline
Posts: 1,803  -  iTrader: (30)
dont know about the scalloping but your are indeed fearless , if not marginally insain , it is cool that it turned out well though .
Old 11-23-2006, 01:43 AM
Ayrton  is offline
Rolling the fretboard edges is common and I am sure your "low tech" approach to the frets is more common than you think.
If it works, then it works.
Old 11-23-2006, 10:09 AM
ashbass  is offline
Ok, here are some pics. It's hard to show the fingerboard rounding but there is a comparison shot with another wizard neck side by side.
Old 11-26-2006, 12:46 AM
frankfalbo  is offline
Crazy Man neck mod. You couldn't have said it better. With as much money as you make buying and parting these things out, you'd think you could afford to place a Stew Mac order for some files and tools.
Old 11-26-2006, 01:30 AM
ashbass  is offline
Old 11-26-2006, 01:46 AM
damn that is a good looking guitar , in the end you can complain about results.
Old 11-28-2006, 05:32 AM
AirGuitar  is offline
Posts: 821  -  iTrader: (5)
Looks great! Just like the neck edge on my EBMM.
Old 11-28-2006, 02:02 PM
screamndemon69  is offline
Posts: 5,676  -  iTrader: (12)
i can only imagine what you have laying around in your personal collection. that has to be Crazy.
cool idea and glad it worked
Old 11-30-2006, 02:03 PM
slugman  is offline
Posts: 256  -  iTrader: (1)
Hey! I bought a neck that had that done. I thought it was some funny kind of wear. Never realized someone probably did it intentionally.
frank falbo
The Super Wizard Neck ??? - is this the neck on my USA Custo Jimi D J-Custom, USA Custom & Prestige Ibanez Guitars 22 12-31-2005 12:02 AM
Jap Wizard neck on a Korean RG?? LonePhantom Other Ibanez Guitars (including Premiums) 5 11-20-2005 01:01 AM
Hands of ACID on a jem7vwh neck ZaPeRoN JEM and Universe Guitars 8 11-06-2005 08:16 AM
What is the best way to drill neck holes in new body..... SilverSurfer2 Tech: Setup, Repairs and Mods 10 04-14-2003 06:41 PM
