Creaky nut problem
I'm having this noisy problem up at the nut now. It seems as if the nut itself is making creaky noises when I either bend the neck or use the whammy. Not sure what I should do to fix that as it's glued to the neck/head (I'm pretty sure its glued). Might not be the nut, but the creaking is pretty damn close to that area. Any thoughts?
Edit: I might have misunderstood the naming, its the locking mechanism that makes these sounds. I seem to call that "nut", not sure if thats correct though.
