Old 09-12-2007, 08:17 AM
Dag  is offline
Posts: 160  -  iTrader: (0)
Custom Gauge Strings for droppedC PRS
Hi!
I've seen couple of times in various threads that you guys are good at calculating string tension. I know nothing about it so I'm here for your help.
I have PRS Cu24 (25'' scale) and I'm playing in dropped C (CGCFAD). I need chunky strings- I strike it hard. I thought of 11-70 GHS Zakk Wylde Boomers, but as Zakk now has endorsement deal with Dunlop these strings are not in production anymore and dunlop only offers 10-60 now ;/
So I thought of getting my custom gauge set. So what will be the best set for: a) 25'' PRS and b) 24 3/4'' Gibson Les Paul Supreme. I think in PRS a starting point can be 11 while on Gibson 12. Please give me an advice and suggest strings that have pretty close tension.
Old 09-12-2007, 01:56 PM
bammbamm  is offline
Re: Custom Gauge Strings for droppedC PRS
yOu might want to consider the new Ernie Ball "Not Even Slinky" strings, they give less sag and aren't flubby when drop tuned.
Bamm
Old 09-12-2007, 06:59 PM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
I second bamm on that, they are getting pretty popular, be warned your gonna need a heavy setup adjustment though for a gauge that high, unless your neck is super stable.
Old 09-12-2007, 07:45 PM
CityofBlindingLights  is offline
Posts: 563  -  iTrader: (0)
DR can offer you a custom set, PM me for more info.
Old 09-16-2007, 07:12 PM
Dag  is offline
I know about Ernie Ball Series, but it sucks. They only offer 11s with 54 on the low E. It's a **** as I'm using 52 in standard tuning. And if considering 12s- which is pretty heavy on violin strings for me, a change on the lowest string is only 2cents. From 54 to 56. Ridiculous. So the only strings still available on market for my purpose can be 11-70 GHS, but for how long.
Old 09-16-2007, 08:23 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
For the 25" scale PRS, a custom set like this should work well:
D: .011" PLAIN = 14.97 pounds
A: .015" PLAIN = 15.62 pounds
F: .019" PLAIN = 15.79 pounds
C: .028" NICKEL WOUND = 16.25 pounds
G: .038" NICKEL WOUND = 16.46 pounds
C: .058" NICKEL WOUND = 17.17 pounds
Total Tension = 96.27 pounds
For a 24.75" scale with the same strings, total tension would drop to 94.35 pounds, two pounds less overall. I'd go with the same custom set though, it'd work well. If these are too light for you, maybe you need to lighten up your touch.
Old 09-16-2007, 08:36 PM
jaxadam  is offline
Classified Watchdog
Posts: 3,043  -  iTrader: (9)
I use 10's on my Custom 22 for standard tuning, and they are great. If I was drop tuning to C, I'd use a standard set of 12's, and I think you'll be fine.
Old 09-16-2007, 08:51 PM
Dee  is offline
D: .012" PLAIN = 17.82 pounds
A: .016" PLAIN = 17.77 pounds
F: .020" PLAIN = 17.5 pounds
C: .032" NICKEL WOUND = 21.44 pounds
G: .042" NICKEL WOUND = 20.07 pounds
C: .054" NICKEL WOUND = 14.64 pounds
Total Tension = 109.24 pounds
With less tension on the low E than even the high E, this is gonna feel and sound like sh*t in my opinion. The low E is laughably sloppy.
Old 09-17-2007, 01:32 AM
*EDIT*: Post removed by user
Old 09-18-2007, 08:22 AM
Dag  is offline
Yeah, Dee, These Ernie Ball sets are to laugh at. People use them cause there's nothing better available on market now;/ sad
ernie ball, gibson les paul, les paul, string tension, zakk wylde
Sims Custom Shop (Chattanooga, USA) PatrickSimsCustomShopUSA Vendors, Auction & Reseller Talk 1373 02-10-2009 04:29 PM
'Custom' Ibanez Shredder stuck in the 80s JEM and Universe Guitars 40 05-16-2007 03:01 PM
free .050 gauge strings Scott of Actual Time Classified Ads: Guitars and Gear 3 08-07-2006 09:29 AM
heavy gauge strings... where from?? Mr. S Other 7-string Guitars 9 10-04-2005 10:09 AM
blaze custom vs custom 7 (also called NEW 7) ibanez7addict Other 7-string Guitars 13 11-14-2004 11:04 PM
