Tech: Setup, Repairs and Mods
Damn buzz! help needed...
03-24-2008, 07:37 PM
rvai
Posts: 458 - iTrader: (
Well somethin like two weeks ago I was playing aint talkin bout love lol, when noticed a small buzzing in the b string 1st fret, so I said ok no big deal, and then all the strings buzzed when fretted at the 1st fret and now the 2nd fret too!
What should I do? the guitar is a 1570 and has fairly low action but it had never buzzed after I set it up the first time, Iīve already changed strings but its still the same, whan can it be? its only in the first frets, and its becoming more annoying each day.
Has this happened to anyone? suggestions?
Well thanks for reading and I hope you guys can help me!
rvai
Find all posts by rvai
03-24-2008, 07:42 PM
Posts: 19,350 - iTrader: (
Re: Damn buzz! help needed...
Loosen the
truss rod
a little.
03-24-2008, 07:49 PM
losgatosrg350dx
Posts: 848 - iTrader: (
ok theres the way you check for neck trueness
press the thick e on the first fret and pres it on he 22 or 24 fret...you should see a bow from frets to strings from each side
at the 7th fret it should be a about 2 buissness cards away from fret 7
if its too low this relates in buzzing and if its too high it relates to high action
also bridge setup too. sometimes after you setup your guitar it aclinates to its enviroment and this happens. to ensure the neck is true with tension, try to check it the way i explained..this is the easiest way to adjust neck true..then its all about the bridge
losgatosrg350dx
Find all posts by losgatosrg350dx
03-24-2008, 08:11 PM
rvai
ok so I measured and there was a .000001mm gap between the string and the fret, so I did as Rich suggested and loosened the trussrod a bit, I guess it should be left a while like that to let the neck adjust right?
rvai
03-24-2008, 08:13 PM
losgatosrg350dx
i would suggest leaving it for a bit
but when you depressed fret 1 and fret 24 at the same time...you measured that LITTLE od a gap between fret 7??
please clarify....
losgatosrg350dx
03-24-2008, 08:41 PM
rvai
well is wasnīt THAT little lol, I was exagerating but for example, light came thru, but I couldnīt get even a sheet of paper between there
rvai
03-24-2008, 08:46 PM
losgatosrg350dx
oh thats way too thin, im thinking 1/64 inch would be normal, yeah i think you should loosen you trust rod
i mean once you depress the first and the 24th fret at the same time you should be able to fit two buissnesscards between the string andf the 7th
fret wire
from there, you can work it either way
losgatosrg350dx
03-25-2008, 07:24 AM
Jem7
Posts: 179 - iTrader: (
I have buzz on high-e string too and i cant fix it. Just high-e keeps buzzing. Action isnt too low and enough relief.
08:44 AM
Jem7
Visit Jem7's homepage!
Find all posts by Jem7
03-25-2008, 08:39 AM
rob777vdy
Posts: 2,575 - iTrader: (
what rich said is right loosen truss rod.but if you do know what your doing DONT ATEMPT you will do more damage to the neck possibly crack the neck,have a
guitar tech
to have a look.rob
rob777vdy
Find all posts by rob777vdy
03-25-2008, 08:55 AM
Rotti
Posts: 3,341 - iTrader: (
Bah, don't be afraid to adjust your truss rod. Unless your a complete knob and you crank the hell out of it your not going to hurt anything.
Rotti
Visit Rotti's homepage!
Find all posts by Rotti
03-25-2008, 09:06 AM
rob777vdy
Rotti
ahhh i always thought this was a delicate job.the guy that gave me lessons years ago told me never to tamper with the truss rod.
rob777vdy
03-25-2008, 01:32 PM
losgatosrg350dx
never adjust your truss rod when there is strings fully in tune!!!
losgatosrg350dx
03-25-2008, 01:35 PM
I cannot believe some of what I'm reading.
http://www.ibanezrules.com/tech/setup/truss.htm
03-25-2008, 02:06 PM
Gudster
Posts: 441 - iTrader: (
losgatosrg350dx
Gudster
Find all posts by Gudster
03-25-2008, 02:11 PM
rob777vdy
ah you learn something everyday,i was told messing around with the truss rod was like defusing a bomb.thanks for the info rich
rob777vdy
fret buzz
fret wire
guitar tech
ibanez guitars
truss rod
wound strings
how to fix low e buzz
how to intonate a buzz feiten yourself
how to get rid of string buzz
is a string retainer needed for an ibanez headstock
when is a refret needed
VSBL: Breed pickup buzz question
MehYam
Pickups & wiring
06:59 PM
UV fret buzz...DAMN!!
SevenStringMonster
02:57 AM
How to elimate fret buzz completely in a guitar?
zerolight
01:06 PM
advice needed for strange fret-buzz on my UVGR - nasty buzz
Superuser
05:35 AM
#@$%*^+@ Rack Buzz
ryan
Gear and Equipment
03:15 PM
07:33 AM
