Originally Posted by albee1952
You need to have the frets checked to see if there is a high fret. Any luthier will have small metal straight-edges just for checking for high frets. You may have a high fret and not be able to eyeball it.
Quoted for truth. It happens over time due to changes in humidity and temperature, among other things. It may not even be clearly visible but, like albee said, your 13th fret is sitting too high if the 12th fret is the only note that's dead.
Lay the guitar flat on a bench with proper support for the lower and upper neck. Take a brass hammer and gently (but firmly) tap the fret back into place on the High E side. Brass is important - it's softer than the fretwire.
Conversely, if you're not comfortable trying this, any
local luthier should be able to fix it.
