Old 04-16-2002, 01:05 AM
BASe L  is offline
Posts: 6  -  iTrader: (0)
Dead sounding string - G string has short sustain - possibly
Hello,
* * I own a pretty worn out Jem 555 and lately the sustain on my g-string is very short. This short sustain happens when I play the string open, and on any fret, so I'm pretty sure the problem is coming from the bridge. Can anybody offer any help with solving this problem. I have gigs coming up and don't have the time to bring it to a tech.
THANK YOU!!!!!
BASe L
Old 04-16-2002, 01:10 AM
Rich  is offline
Heavy fretwear?
Old 04-16-2002, 01:53 AM
Texter  is offline
Posts: 839  -  iTrader: (0)
Worn saddles can only be replaced with new ones as far as I know...
Old 04-16-2002, 08:36 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
did you replace the strings?
i ask you this cause i realized that many ppl don't replace the strings when they got a used guitar...
try looking at the G saddle, look at it closely and check out for any dirt or stuff right where the string lays, or between string and saddle.
Old 04-16-2002, 10:31 AM
BASe L  is offline
Hi!
Thanks for the help. The strings are fresh, so I doubt the gstring itself is the cause. Also, could it
be heavy fretwear even though it has the same short sustain when I play the string open? It doesn't
rattle or buzz, it just sort of sounds like a banjo string. Anyways, the guitar is pretty beat up, and I am
saving for a 7DBK, but I'm hoping I can fix this quick because it will be quite some time before I can afford the new guitar.
Thank you!
Mike
Old 04-16-2002, 05:00 PM
SalemB  is offline
Posts: 848  -  iTrader: (0)
You can try to switch the saddles on the G and D string. If the problem have moved to the D string you will need a new saddle. If it stays on the G string you might want to do a closer inspection of the nut.
Old 04-16-2002, 05:02 PM
Rich  is offline
I still lean toward fretwear. The frets will be way more worn than the nut or the saddle and will just kill tone and sustain.
Old 04-16-2002, 06:03 PM
musicdr  is offline
Posts: 671  -  iTrader: (0)
On the last set of strings,did you have the same problem?
Old 04-17-2002, 12:28 AM
BASe L  is offline
Thank you all for the help! I will try fooling around with the saddle. I seriously doubt fret or nutwear because it sounds dull when played open or fretted, I guess it is a saddle problem. I'll post when I try something.
Thank you so much again!!!
BASe L
Old 04-17-2002, 03:42 AM
nuno  is offline
La Famiglia...
Old 04-17-2002, 11:15 AM
BASe L  is offline
Ahh fellow Italians! Nice to see, considering Vai is one.
Ciao!
BASe L
Old 04-17-2002, 05:14 PM
nuno  is offline
yeah...
and Satriani, Petrucci, Balducci, Patitucci, Gambale, Tafolla, Trovato, Appice bros and so on... ow! how many italians! that's an invasion!
[size=0.5](oh yeah... and Cianciulli too!)[/size]
Old 04-17-2002, 07:08 PM
SalemB  is offline
My last name, Trongmo, sounds Italian if it's pronounced the correct way.
Can I be an Italian too? :biggrin:
Old 04-17-2002, 10:55 PM
BASe L  is offline
Sure just change the 'm' to an 'n' and it could work!
hehe
BASe L
Old 04-18-2002, 03:40 AM
nuno  is offline
hehe...
well, Salem, luckily for you... you're not Italian!
Trongmo is a very very weird word/name here, it could sound Italian for you non-Italians, but not for us, defenetely.
if it was Trongimo, Trogno, Trongo, then you were Italian, but Trongmo... oh, pretty weird!
