Hi,
I've been working my way through the setup guides here and on Rich's site, and my guitar is definately a LOT better than when I first got it.
I'm still not totally happy with the action height though.
When I first got it I lowered the bridge a little which helped, but it would't go much lower without buzzing at the 1/2nd frets on the B string. Being stupid and impatient (I didn't have the trussrod adjustment tool) I fitted a little cardboard neckshim
and this helped.
At Jemfest Dex & Jono pointed out that bridge was really high, so I got home, removed the
neck shim, set the trem angle, lowered the bridge, adjusted the trussrod, let it settle for a couple days and tweaked the
bridge angle again. This made it *much* better, but the bridge is currently lowered as far as it will go and the action is still a bit higher than on my old RG470. I don't have feeler guages so using an ultra-technical method of sliding a plectrum under the 24th fret, it seems like the action there is slightly less than 2mm (high E) and slightly higher than 2mm on the low E.
Am I aiming for too low an action, or is there something else I can do (like putting the neck shim back)?
