Do I need to change the springs on my Edge
Hi all,
I'm fixing up an old RG550 (1988 I think, in RFR with matching headstock).
When I pull back on the trem, the action (of the trem) seems a little stiff. I appreciate that the setup may need some work, but I think I've got it real close to how it should be.
When I get the trem angle set right (very slightly above neutral) the claw is only about 3-4mm from the edge of the trem cavity. Is this normal? Are my springs too tired?
Thanks
Neil
BTW, I should have added that I'm using 9-46 strings. Maybe I should try 9-42's, what do you reckon?
Reason: Added more info.
