Old 11-25-2005, 12:35 PM
tTz  is offline
Posts: 446  -  iTrader: (0)
Dodgy neck shim?
Midway through my set up, and I decided to ask about the neck shim on my RG. I've always wondered why it was a such a wierd angle, and thought that now is the perfect time to change it if I have to. It also seems to miss the middle of the nut (looking down through the screwholes, I can see it on either side, but not the middle - you can actually see this on the pic). It's also pretty sharp and I've caught my fingers on it a good few times. I could always file it down though.
There you go. Anyone know why it's like that?
Old 11-25-2005, 12:59 PM
ScottB  is offline
Posts: 2,208  -  iTrader: (12)
Images: 8
Re: Dodgy neck shim?
Actually, that's the brass nut shim. Just loosen the screws behind the nut and you should be able to slide it back into place. If there is a neck shim, it would be in the neck pocket area of the body, under the heel.
Old 11-25-2005, 01:16 PM
tTz  is offline
Nut shim, that's what I meant! Can a mod edit the title for me? God I'm such a fool.
Is it supposed to be like that though? That's what I was looking to find out. It seems a bit of an awkward way to do it, sticking out the sides. Plus it doesn't appear, as I said, to be a rectangle, more of an irregular shape.
I suppose taking it out won't do any harm (at least, none that I can't repair), so I might move it and see what happens.
Old 11-25-2005, 02:06 PM
tTz  is offline
Well, I've adjusted it so it sits flush under the nut. By the way, can the nut only go on one way around? I didn't realise one side was taller than the other when I took it off, otherwise I would have looked.
I'll see what happens when I put the strings on.
Old 11-25-2005, 08:22 PM
ibanez.shredder  is offline
Posts: 310  -  iTrader: (0)
Yes it can only go one way around. The taller side faces the body.
Old 11-26-2005, 10:08 AM
tTz  is offline
Yeah, I got it on fine...trem is ****ed though.
Old 11-26-2005, 04:47 PM
tTz  is offline
Or possibly not...I thought the trem was beyond repair, turns out a few turns of some screws and all seems good now...just got to get around to tuning it again, and it should be ready to play! Tuning is such a nightmare though, I'm leaving it til tomorrow.
neck shim, nut shim
Painted neck? Sanded neck? Drache713 Other 7-string Guitars 28 12-25-2005 12:45 AM
I added a neck shim to my 555 but the action is the same... Filipe Tech: Setup, Repairs and Mods 7 11-12-2004 01:24 PM
different neck sizes on the RG models fazehans Other 7-string Guitars 4 10-26-2004 02:49 AM
WHAT IN THE WORLD???!!!...@.@ JS2000 neck on JS1000??? Mich JS (Satriani Model) Ibanez Guitars 7 10-12-2002 04:00 AM
neck shimming, buzz, no low action... what to do?!? - I can' berntsen Tech: Setup, Repairs and Mods 2 04-16-2002 05:34 PM
