Old 02-01-2008, 07:03 AM
bdk  is offline
Posts: 278  -  iTrader: (0)
Does a Edge Pro II fit in a Lo TRS cavity?
I have an S470FM, a great guitar, well...except for the trem, can an Edge Pro II fit in there? the original edge almost fits, but not quite. Is the edge pro II ok? or is it junk also?
Old 02-01-2008, 09:47 PM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Re: Does a Edge Pro II fit in a Lo TRS cavity?
The EP II is a decent bridge but will require some routing to make it fit as the block is way bigger as compared to the TRS (or the Edge for that matter). I have fitted the Edge in place of the stock bridge on that same guitar. What it takes is: pull the studs and inserts, route the flat part (where the inserts go) deeper by 3mm. re-drill the insert holes with an 11mm bit and go 3mm deeper so you can press in a set of locking stud inserts. Then an Edge bridge should pop in like it belongs.
edge bridge, locking stud
I just put an Edge in my RG470! DirtyBird31 Tech: Setup, Repairs and Mods 10 09-14-2007 12:22 AM
Can I use Edge posts with an Edge Pro?? PatrickSimsCustomShopUSA Tech: Setup, Repairs and Mods 8 10-26-2006 11:00 AM
Edge III Mystery... Solved? eclecticmage Tech: Setup, Repairs and Mods 47 10-22-2006 01:08 PM
The Edge II and the FR Speed Loader Flame_Virtuoso_6688 Other Ibanez Guitars (including Premiums) 0 06-16-2005 05:38 PM
Dimensions of trem cavity adn stud placement for Lo Pro edge Paul Secondino Tech: Setup, Repairs and Mods 2 09-21-2004 09:13 PM
