Old 01-28-2006, 03:44 PM
Code001  is offline
Posts: 74  -  iTrader: (4)
Does my Neck Need to be Shimmed?
Here are the specs on my guitar:
Neck Relief - .004'' (.102mm) measured at the 9th fret
Low E action - 1/16'' (1.5875) measured at the 12th fret
High E action - 1/32'' (.7938mm) measured at the 12th fret
Gap Between 2nd fret when when holding down the 1st fret - .013'' (.330mm)
The reason I ask is because my trem is pretty far down in the cavity. When it is set up properly, it looks like this:
Right now I actually have it on more of an angle to allow for a bit more pull-up, even though it causes some slight tuning stability problems (but not much). Maybe the nut is too high? I wouldn't be surprised if it is. My strings are 10-52s and it's tuned to Eb at the moment if that makes much of a difference. The guitar plays great though and I plan on buying 2 more Ibanez guitars this year.
Old 01-28-2006, 04:11 PM
Liggy  is offline
Posts: 221  -  iTrader: (4)
Re: Does my Neck Need to be Shimmed?
You dont actually mention if the guitar previously had a different gauge string fitted prior to your problem, or have you suddenly started to play using 'dropped' tuning?
Both can make a lot of difference to the angle of trem, as well as intonation, relief and action.
This could be as simple as adjusting the trem springs or a little more complex procedure to set up everything else.
If in doubt, take it to your local pro.
Old 01-28-2006, 04:55 PM
Code001  is offline
I do all my own setups. I set the trem up this way, along with all those specs. The trem is the same as it has been for about a year now. I just decided to ask this question now though. I'm just asking if it's normal for the trem to be this low with my specs.
Old 01-28-2006, 05:07 PM
honky_tonk  is offline
Posts: 197  -  iTrader: (2)
i think its normall specailyl being you have the low profile
Old 01-28-2006, 05:52 PM
Liggy  is offline
Id say definately Yes!!
The guitars i have with the Edge Pro (and lll) are set up with trem parallel to body too
ibanez guitars, neck relief, trem springs
The Super Wizard Neck ??? - is this the neck on my USA Custo Jimi D J-Custom, USA Custom & Prestige Ibanez Guitars 22 12-31-2005 12:02 AM
Jap Wizard neck on a Korean RG?? LonePhantom Other Ibanez Guitars (including Premiums) 5 11-20-2005 01:01 AM
Hands of ACID on a jem7vwh neck ZaPeRoN JEM and Universe Guitars 8 11-06-2005 08:16 AM
What is the best way to drill neck holes in new body..... SilverSurfer2 Tech: Setup, Repairs and Mods 10 04-14-2003 06:41 PM
Changing Vine inlay colors - things that make you go hmmmmmm tomizm Tech: Setup, Repairs and Mods 34 04-13-2001 03:14 PM
