Tech: Setup, Repairs and Mods
Does string gauge affect fret rattle ?
01-17-2009, 06:09 AM
Silverburst
Posts: 488 - iTrader: (
I was wondering: 009-042 tuned E vs 010-046 tuned E, same trem height and amount of neck bow.
Do thicker strings need to be tightened a bit more to achieve the same tuning? If so, I would guess this affects things like fret rattle (in a positive way)?
Silverburst
Find all posts by Silverburst
01-17-2009, 06:15 AM
Jacob K
Posts: 183 - iTrader: (
Re: Does string gauge affect fret rattle ?
Yes, thicker strings generally need to be tighter to achieve the same tuning. And sure, that affects fret rattle. Also, some string brands/series are tighter than others. I was told that D'arrios, for example, are more spongy than Ernie Balls.
Jacob K
Find all posts by Jacob K
01-17-2009, 06:33 AM
GuitarBizarre
Posts: 1,182 - iTrader: (
Yes, tighter strings tend to rattle less, higher guages are tighter thus less rattle.
GuitarBizarre
Find all posts by GuitarBizarre
01-17-2009, 07:33 AM
Silverburst
Thx. So it would be a good idea if I want to detune a half or a whole step I use a higher
gauge
as well. Could 009-042 tuned E have about the same rattle-ratio compared to 010-046 tuned D# or would a drop D still hold up as well.
Silverburst
01-17-2009, 09:16 AM
jemaholic
Posts: 2,806 - iTrader: (
The thicker gauge strings are physically fatter and if your action is low the fatter strings will take more room to vibrate- sometimes those fatter vibrating strings that need more room run out of room and vibrate against the frets.
PLUS- your tension on the neck is greater with thicker strings and it may be pulling the neck into a "bowing" curve that frets-out the string too.
Tighter strings don't move as much as loose strings either.
~j
jemaholic
Visit jemaholic's homepage!
Find all posts by jemaholic
01-17-2009, 09:42 AM
Silverburst
So Jemaholic:
Fatter->more vibration space.
But fatter means tighter to reach the same pitch->less vibration.
So in the end... not that much of a difference ?
About the bow indeed, but I'd adjust the thrus rod, intonation and the whole setup to have the action back at where it was with my 009-42 setup so I'd have a fair comparison.
What do you mean exactly with "thighter strings"? More tension because of higher gauge, or the composition of the strings themselves (tighter and less tighter string brands)?
Silverburst
01-17-2009, 09:55 AM
The Euphor
Posts: 2,948 - iTrader: (
Both gauge and composition affects the tension of a string.
Fatter = more vibration space. Period. That is when it's tuned to the same pitch.
The Euphor
Find all posts by The Euphor
01-17-2009, 11:09 AM
waylay00
Posts: 3,763 - iTrader: (
But also, remember that lighter gauge strings are easier to press, so you can have them a little higher, but still feel like low action on bigger strings.
At least that's how I sense it.
waylay00
Find all posts by waylay00
gauge
how much do pickups affect tone
how to fret level
what "string gauge" does muhammed suicmez use
how to set the string tension on zr tremolo for 10 gauge strings
where to buy guitar string sin southampton
Blocking the Trem, Does it Affect String Tension?
SixStringShredder
11:07 AM
If I'm getting fret-rattle from the 12th to the 18th fret...?
Superuser
01:11 PM
Horrible Fret Rattle!
Dee
09:20 AM
Fret wear affect sustain?
bobojem
01:10 PM
Strange fret buzz - Only at 16th fret, G string
carlos seo
12:12 AM
04:04 AM
