Tech: Setup, Repairs and Mods
Dumb question - adding 4th spring on edge block
09-09-2002, 11:16 AM
horstausmforst
Posts: 663 - iTrader: (
Hi there, I just wanted to know where to put the fourth spring when the edge block just has 3 holes in it.
The outer 2 springs straight into the outer holes and the inner 2 angled into the same hole?
Or do I have to use the holes meant for the spring lock screws??
Umm.. and if you want me to, I'll explain later why anyone would ever want to add a fourth spring, but thats another story
horstausmforst
Find all posts by horstausmforst
09-09-2002, 11:21 AM
jemsite
Administrator
Posts: 9,271 - iTrader: (
you'll have to use one of the threaded holes. either one is fine... glen
jemsite
Find all posts by jemsite
09-09-2002, 11:28 AM
horstausmforst
Thats a fast answer, thanks!
But wouldnt that somehow harm the thread in that hole?
horstausmforst
09-09-2002, 04:00 PM
Posts: 19,355 - iTrader: (
Actually, you want to use both threaded holes, leave the center open
I've pulled out spring and re-attached the lock bar, no sweat.
09-09-2002, 04:10 PM
jemsite
Administrator
i'd use one threaded hole... then use the other to screw down the
retainer bar
. also in the TECH SETUP area of this site, there is photos of using an alternate springs to accomplish this (perhaps with longers screws too).
jemsite
09-09-2002, 04:12 PM
The lock bar is fairly unnecessary, I'd much rather have equal tension on each side of the bridge
09-09-2002, 04:31 PM
jemsite
Administrator
LOL. the lock bar is a significant improvement over the OFR. Equal tension is somewhat irrelevant considering the
string gauges
...glen
jemsite
09-09-2002, 06:01 PM
Equal tension is more relevent to me than a neat gadget that never finds it's way back on my players
09-09-2002, 06:05 PM
jemsite
Administrator
agree to disagree. never have a player w.o the spring lock bar
jemsite
09-09-2002, 06:06 PM
I agree, to disagree
09-09-2002, 06:56 PM
Tsorovan
Posts: 260 - iTrader: (
I've never ever ever seen a spring shoot off loose from the
trem block
without some extraordinary help...
Tsorovan
Find all posts by Tsorovan
09-09-2002, 07:04 PM
Which was my point
Even under extreme whammyonics [I suck at playing anymore but I can whammy with the best of them, covers up for lack of talent!]
09-09-2002, 07:09 PM
jemsite
Administrator
i guess they engineered that part just to make the edge parts diagram look more impressive and complicated.
abrupt pull-up will dislocate a nice, broken-in spring. your mileage will vary... glen
jemsite
09-09-2002, 07:13 PM
Hasn't happened to me yet, when it does, I'll sing a different tune
I had my 540R hit by a tractor trailer doing 70 on I95, that threw a spring off the bock, didn't break a string though
09-09-2002, 08:25 PM
Lonely Raven
Posts: 491 - iTrader: (
Which was my point
Wow! Rich is really C.C. DeVille!!
Lonely Raven
Visit Lonely Raven's homepage!
Find all posts by Lonely Raven
edge trem
floyd rose
retainer bar
string gauges
trem block
how to set up a edge 3?
is it ok to use only one spring with a trem claw
is my edge trem bar in all the way
02:32 PM
