Old 09-11-2007, 01:43 AM
TheNocturnal  is offline
Posts: 9  -  iTrader: (0)
Edge 3 Tremelo Blocking
I've heard that the Edge 3 Tremelo is HORRIBLE. Like never stays in tune. If i blocked it like an OFR would it make any difference in the tuning?
Old 09-11-2007, 02:09 AM
Ki swordsman  is offline
Posts: 1,273  -  iTrader: (0)
Re: Edge 3 Tremelo Blocking
well.. does YOURS stay in tune? if it does then there's no problem. if it doesn't, go for it.
don't go doing work for the sole reason that you've heard others have had problems before. personally i've read if setup well it can be decent.
and if you blocked it, it would be the same as any other blocked trem, the tuning will be fine
Old 09-11-2007, 02:34 AM
I dont have one yet <_< I'm seeking an Ibanez Xiphos for backup to my jackson DKMGT(once the dkmgt is fixed the xiphos will take over lol) thanks for the help!
Old 09-11-2007, 03:13 AM
cool, yeah i kinda guessed you might not have one yet, but bottom line is, it can be blocked or setup well enough, so don't worry til after you get the guitar and actually start having problems with it
Old 09-11-2007, 05:40 PM
Now my problem is that no one in baltimore has the xiphos for me to try.
Old 09-11-2007, 11:08 PM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
I dont know if youll like the body shape. Its definitely not for everyone. If your into explorers, destroyers, or iceman body styles, or even an ml dean, it might not be that big of a change for you. The trem can be setup fine, but is inferior to the higher end units.
Old 09-11-2007, 11:53 PM
Racerx2k  is offline
Posts: 1,076  -  iTrader: (0)
I have an Edge III, and it has been rock solid from day one. All that talk is mere newb-b.s..
Old 09-12-2007, 12:37 AM
I love the razorback and I own a warlock, i'm good
So what would I need to do to play with 11 gague and drop into C standard/drop C? like spring tension and ETC.
Is the xiphos a good choice? I love metal. Just flat out.
Old 09-12-2007, 08:02 AM
Well 11 gauge strings would require an extra spring for standard tuning but if your wanting to play in c standard all the time then perhaps not. The stock strigns on the ziphos are probably 9's. If i were you though id try a set of 10.5 daddarios.
The guitar would need a full setup for such a change in tension. Full vibrato system adjustment, truss rod, intonation etc.
Old 09-13-2007, 01:08 PM
I'll stick with 10s then, thanks.
Old 09-13-2007, 01:21 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Go try one at Chuck Levins in greenbelt or Melodee Music in Sterling. Do it on a saturday and enjoy the drive.
Jimmy
Old 09-16-2007, 12:09 PM
HeavyMetal4Ever  is offline
Posts: 1,172  -  iTrader: (0)
Havn't tried a Xiphos, but i've got a VBT-700.
The D-Activator pickups are excelent for metal, and the thru neck wizard II is great.
Rock on!
body shape, gauge strings, truss rod
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
HOW TO SET UP AN EDGE PRO TREMELO UNIT. slash_88 Gear and Equipment 0 10-07-2006 11:42 AM
Tremelo Angle for Edge Pro 2 Rochus Tech: Setup, Repairs and Mods 2 09-27-2004 12:19 PM
Blocking an Edge Pro nuno Tech: Setup, Repairs and Mods 4 10-06-2003 08:57 AM
Edge Blocking - Read before you lock it! BZ Beetle Tech: Setup, Repairs and Mods 4 02-09-2003 01:57 AM
