Tech: Setup, Repairs and Mods
Edge arm socket in EPII
07-15-2005, 11:29 PM
pinto79
Posts: 371 - iTrader: (
I'm going to be installing an Edge arm socket into the Edge Pro II trem on the JS100 of one of my students. She's totally worn out the back of the arm where the set-screw is.
I will photograph the job so that others can try this too...
Or maybe I should just make the service available for a fee... hmmmm... I'll think about it!
I'll keep you all posted!
pinto79
Find all posts by pinto79
07-15-2005, 11:34 PM
Posts: 19,350 - iTrader: (
Re: Edge arm socket in EPII
Somebody posted a mod of adding some shims under the set screw to keep it from wearing through the rubber [or whatever it is]
07-17-2005, 08:14 PM
pinto79
I got the bridge apart today and there is a nylon-type insert in the original arm socket. It's totaly trashed in this one.
Thanks for the quick service on the parts for this project Rich!
Rich, do you happen to know what the thread size and pitch is on the arm socket?
I'll post pics when the job is complete.
pinto79
07-17-2005, 08:22 PM
I've got no idea, take the holder to the hardware store.
I assume you're drilling, tapping, and countersinking?
07-17-2005, 08:31 PM
pinto79
I'm drilling and tapping, but I don't think the wing is thick enough to countersink. I have to measure it first.
And I guess it's off to Home Depot to find a nut that threads on so that I know what the thead is...
pinto79
07-23-2005, 06:48 PM
pinto79
As promised, here are pics of the finished product, I couldn't tap the hole that the
arm holder
went into as the thread is non-standard (ie, Ibanez only) and I could not get a tap with the right thread pitch. The socket is a tight fit and there is no movement with the arm in it.
Anyway, here's the pics!
I'm taking any questions you may have!
pinto79
07-23-2005, 06:54 PM
I refuse to believe the thread is proproetary. Most likely your source just didn't have the right tap. Nice looking when finished none the less
07-23-2005, 07:04 PM
pinto79
Well, an 8mm thread is too small and a 10mm thread is to big. I couldn't get my hands on anything that fit properly, so I improvised!
Thanks for the compliment on the job Rich! The whole thing is so much nicer feeling than the old...
I'll update the report once I get the guitar strung and floating...
pinto79
07-23-2005, 07:06 PM
9 maybe?
07-23-2005, 07:24 PM
pinto79
9 maybe?
That's the stupid thing. I live in Canada, a METRIC country and every fastner place I contacted had no idea if 9mm existed and no one would confirm if they had metric drills or taps in stock...
What a backwards place this is...
pinto79
07-23-2005, 08:07 PM
steve
Posts: 590 - iTrader: (
pinto79 - do you have access to a Brafasco?
They can get pretty much anything you need...
steve
Visit steve's homepage!
Find all posts by steve
07-23-2005, 09:11 PM
damo7v
Posts: 1,150 - iTrader: (
i like your work pinto. are you offering your services to other EP2 users?
damo7v
Find all posts by damo7v
07-23-2005, 10:48 PM
Distantshore
Posts: 3,671 - iTrader: (
That looks great, very professional!
Distantshore
Find all posts by Distantshore
07-24-2005, 12:23 AM
sniperfrommars1
Posts: 3,302 - iTrader: (
This is a good idea in my opinion still the new trem is way better than the trs, but nowhere new the original edge designs, but at least they are bridging the gap, an improvement is an improvement and ill take it
sniperfrommars1
Find all posts by sniperfrommars1
07-26-2005, 02:26 AM
pinto79
damo7v
Sure, anyone who wants this done, please PM me for a quote.
pinto79
arm holder
will edge zero pro fit edge 3 route?
how is the edge zero?
is my edge trem bar in all the way
Edge III swap for another Edge model trem?
lespaulreedsmith
36
03-14-2009
06:10 PM
Edge mysteries solved!!......? - Answers to some common ques
Jason Stone
09:35 AM
I just put an Edge in my RG470!
DirtyBird31
12:22 AM
lo pro edge vs edge pro 7
cakewalkr7
12:23 AM
06:57 AM
