Go Back   Jemsite > Toolbox: Setup, Repairs and Mods > Tech: Setup, Repairs and Mods
Old 10-17-2006, 07:26 AM
eclecticmage eclecticmage is offline
Posts: 61  -  iTrader: (0)
Lightbulb
Edge III Mystery... Solved?
Hey all,
For those who are interested, it is possible to fit an Edge trem into and Edge III routing without any major modifications. Matter of fact I put some locking studs into my Edge III body and then tested with an Edge trem I have for another project guitar. It fit like a glove with full range of motion. The only mod I did was to widen the Anchor holes slightly to accommodate the new locking anchors. Over all, the worst part was resetting up the guitar. So I suppose if an Edge will fit in all its honking glory, it is theoretically possible for an Edge Pro to fit there too. I would welcome comments. Thanks for reading.
Old 10-17-2006, 08:00 AM
King Knall King Knall is offline
Posts: 2,444  -  iTrader: (0)
Re: Edge III Mystery... Solved?
Originally Posted by eclecticmage View Post
Hey all,
I don't think the EP is able to fit in the EIII's cavity because the design is different. The EIII was designed according to the specs of the Edge, so I think that's why the Edge is able to fit in the EIII's cavity.
Old 10-20-2006, 07:49 PM
madpickin03 madpickin03 is offline
Posts: 531  -  iTrader: (1)
whoa, pics plz
btw the EdgePro has totally different routing from an Edge
Old 10-21-2006, 01:44 AM
PatrickSimsCustomShopUSA PatrickSimsCustomShopUSA is offline
Posts: 1,166  -  iTrader: (0)
Hmm, somethings not right. I just read this thread, got up, grabbed an RG 320FM that has an edge III, grabbed an edge and it WOULD NOT FIT. Width wise it was fine, but the cavity isn't long enough. The allen head bolts on the back of the trem rest on the body all the way to 1/4" further back than the 320 is routed. I grabbed another edge same thing. Grabbed a lo pro same thing, grabbed an edge pro and it won't even go in. So, I have to beg to differ, an edge will not fit into an edge III routing without the allen head bolts resting on the back of the body, which in turn doesn't allow the edge to go all the way down in the cavity. Either one of two things is wrong, your either A) Not using an edge but something else, or B) Your body is not a routed for an edge III, which is probably the case. I grabbed two other 320's that have edge III's and tried them and the edge wouldn't fit in any of them, the trem cavity needs to be lengthened by about 1/4" to fit and not hit or rub in the back. I'll post pics in about 5 mins
Old 10-21-2006, 02:06 AM
Heres the pics, Edge Trem in an Edge III route will not work. This is a brand new RG 320FM.....also, the egde trem is pushed all the way forward to give as much clearance as possible, it actually would sit about a 1/16" further back if the studs were in, which woul dmake it over hang even more, as well as rub in the corners to the point that the tremelo wouldn't be able to move. I also test fitted this on two other EDGE III routes, and they were all exactly the same, the routes were 1/4" in length to short for an edge trem.
Old 10-21-2006, 02:11 AM
crevis crevis is offline
Posts: 2,599  -  iTrader: (1)
Did you mean edge 2??
Old 10-21-2006, 02:34 AM
Who? Not me, I meant edge III. The original poster said an edge trem would fit in an edge III route. I said not it wouldn't, b/c as you see above I have an RG 320 FM which is routed from the factory for an edge III and an edge will not work, which is what is in it in the pictures. All I was saying is he must have some other route other than an edge III, and edge III route is not long enough to accomodate an edge trem.
Old 10-21-2006, 02:38 AM
Yeah i said that to the dude that started the thread. I never noticed the E3 was that small.
The models get larger as they go up so that you cant retrofit E3 with edge or edge with lo pro etc
Old 10-21-2006, 03:15 AM
Yea, the edge III is very small
Old 10-21-2006, 05:53 AM
Edge III Installed
Edge
Edge Floating Top and Back
Edge Resting in body
Now please tell me I am mistaken about the edge III being installed in this guitar. I would love to know that it has something other than that installed. Otherwise it looks like it fits rather nicely in there with room to play.
Thanks.
Old 10-21-2006, 05:57 AM
I am not trying to sound like an @$$ but if I honestly do not have and EIII then what is it. I got this guitar from factory. The only thing I changed was the locking studs mod and a tremol-no. Otherwise I havent changed the route.
Old 10-21-2006, 06:01 AM
Rich Rich is offline
Posts: 16,463  -  iTrader: (19)
Thanks.
You have every saddle on the Edge pushed full forward so the intonation is crap. Making the bridge fit [and how did you get the tongues on either side of the knives to fit in without deepening the body corners] and having it properly intonated evidently wasn't an issue with you.
  #13
Old 10-21-2006, 06:14 AM
The tounges just fit in the route though I do see where a problem from that would be. As for the intonation, I had not considered that as this edge still has yet to make it into an actual guitar for use. Now with that brought to light, I could see how that would not fit and how it is possible for me to be wrong. I admit it. Sorry guys, my bad.
  #14
Old 10-21-2006, 06:35 AM
That is obviously a 350 so maybe some 350s are made from excess trs bodys when they switched trem lineups, i know for sure that an edge will fit a trs route, maybe not trs 2 i dont know. Even the Edge 3 looks far too small for that route. and yeah if the intonation ends up like mine, the g bolt will hit for sure.
  #15
Old 10-21-2006, 06:40 AM
You know come to think of it looking back at SCS' pics. It looks like the saddles are riding kind of far forward too. At least comparatively they look like they land around the same area in relationship to the studs as my edge does. Thanks all for commenting, even though some of them sounded more smug and condescending than others.
Normandy Chrome Hardtail Archtop Guitar
As low as $2300
at 3 sellers
Washburn WI50 Electric Guitar Black
As low as $399
at 7 sellers
Members with more than 50 posts don't see this bar
Seagull Artist Series Mosaic Dreadnought QII Acoustic-Electric Guitar Natural
As low as $635
at 4 sellers
Hao RB-1 Rust Booster
As low as $135
at 10 sellers
Fender Super 250LR Nickel/Steel Light Regular Ball End Electric Guitar Strings
As low as $3
at 3 sellers
Carl Martin Hot Drive 'N Boost mk 3 Pedal
As low as $196
at 7 sellers
Hercules Stands GS432B Tri Stand Guitar Stand
As low as $74
at 10 sellers
Fender 9050L Stainless Flatwound Bass Strings
As low as $18
at 4 sellers
Breedlove Retro Series OM/SM Acoustic Guitar Natural
As low as $610
at 6 sellers
Luna Trinity 12-String Grand Auditorium Acoustic-Electric Guitar Natural
As low as $487
at 6 sellers
Ovation Celebrity SE Deluxe CSE44 Acoustic-Electric Guitar Honey Burst
As low as $380
at 4 sellers
eBay
As low as $0
at sellers
Schecter BlackJack ATX C-1 FR Electric Guitar Aged White
As low as $899
at 3 sellers
IK Multimedia AmpliTube 2 Electric Guitar Amplifier and Effects Modeling Plug-in
As low as $195
at 12 sellers
edge trem, jem neck, joe satriani, locking stud, locking studs, steve vai, strat plus, trem arm
close
Sign up for free and join one of the largest communities of Jem guitar lovers!
Our members will be glad to help you with anything you need!
Join over 30,000 JemSite members!
Email
Email Confirm Email
Username
Password Confirm Password
I agree to the website rules
