Old 02-02-2007, 02:48 PM
Shredtillubleed2death  is offline
Posts: 18  -  iTrader: (0)
Edge III setup
Hey i've just bought Rg370dx and is a very good guitar.I've trouble setting up the bridge angle.The construction of the bridge is in a such a shape that i cannot figure out whether it is parallel to the body or not.
Another thing if i do a dive bomb the guitar comes in perfect tune but if i pull it up every strings are a bit sharp,Why?Can anyone give me a picture of the Edge III angle?
Old 02-02-2007, 03:28 PM
Demogorgos  is offline
Posts: 704  -  iTrader: (0)
Re: Edge III setup
Regards,
JP
Old 02-02-2007, 03:33 PM
extremist777  is offline
Posts: 239  -  iTrader: (0)
Re: Edge III setup
Man!, the Edge III Really Sucks! even when it is in a correct setup... Can't even do the flutter thing, and the bar is loose. Edge Pro is the best, but haven't tried the ZR yet.
Old 02-02-2007, 04:18 PM
Racerx2k  is offline
Posts: 1,076  -  iTrader: (0)
Re: Edge III setup
Don't listen to the haters, man. That's just something said when they don't know how to take care of their own guitars.
A properly setup Edge II will hold tune, just fine. You just seem to have something off, right now. I have an Edge III, and do pull-ups, all night, and it stays in tune, perfectly. Have someone look it over for ya, and don't give up.
Old 02-03-2007, 12:59 AM
Re: Edge III setup
Ive read the tech section of the ibanezrules and setup my edge III but still the same problem , when i pull up the tune of every strings go a bit sharp.
Racerx2k can u give me a picture of ur edge III.
Its a lot better bridge than the ilt1 bridge.
Old 02-03-2007, 01:04 AM
crevis  is offline
Posts: 2,599  -  iTrader: (1)
Re: Edge III setup
Compared to other low priced trems, it's great but it has its limitations.
Old 02-03-2007, 11:37 PM
Racerx2k  is offline
Re: Edge III setup
Sure. Here you go, but I don't know if it's really gonna buy you anything. Not the best pic, but best I could do with this ****ty camera. Took me 10 minutes just to get it to look THIS good!
Old 02-04-2007, 10:07 AM
Rob A  is offline
Posts: 69  -  iTrader: (0)
Re: Edge III setup
It doesn't suck. Really. If you read the manual that comes with the guitar (and if it didn't, you can probably get it online or email for it), it'll tell you exactly how to set it up correctly. With that and the guide here, you should be set.
And for those who don't know or can't be bothered to read: to make the trem arm tighter, put the trem arm in, dive bomb all the way AND HOLD. Now on the back of the trem block it self (the bit that has just made itself visible by you bombing), there is a small allen screw. Tighten this with an appropriate allen key. Now it is tight.
And yes, it does do the SV flutters/gargles/random wacky stuff.
Old 02-04-2007, 10:54 AM
Racerx2k  is offline
Re: Edge III setup
It DOES flutter, but not quite as well as my old original Edge. Probably due to less mass, plus the springs may still need to break in. Still, it IS a good trem.
Old 02-04-2007, 12:30 PM
Ironjose  is offline
Posts: 1,059  -  iTrader: (0)
Re: Edge III setup
of course... the weight have the issue here...
Old 02-05-2007, 12:18 PM
Re: Edge III setup
Thanks guys u all are really helpful.
I didnt get any manual with the guitar.Where can i get it?And also how tight do you all lock the nuts?
Old 02-05-2007, 04:05 PM
Racerx2k  is offline
Re: Edge III setup
I've been known to round socket heads, and strip threads at work, so I wouldn't exactly be a good benchmark for THAT one! hehe.
Old 02-05-2007, 10:49 PM
crevis  is offline
Re: Edge III setup
All the manuals are on the ibanez website.
Old 02-05-2007, 10:53 PM
mi2tom  is offline
Posts: 7,522  -  iTrader: (4)
Re: Edge III setup
Edge3 is awesome if you ask me, just need to set it up properly
Old 02-06-2007, 01:00 AM
Ironjose  is offline
Re: Edge III setup
is awesome ??? in what way? i've heard nothing but bad things about it...
bridge angle, cavity cover, edge trem, esp arming adjuster, guitar body, spring cavity, trem arm, trem block, wilkinson trem
Installing peizos into an edge pro bridge. merman_93 Tech: Setup, Repairs and Mods 12 01-01-2009 12:15 PM
I just put an Edge in my RG470! DirtyBird31 Tech: Setup, Repairs and Mods 10 09-14-2007 12:22 AM
Need A Really Good Quality Pic Of An Edge Tremolo IbanezGirl Other Ibanez Guitars (including Premiums) 27 11-03-2006 07:26 PM
I want to put an Edge in my TRS Cavity! Worth it? DirtyBird31 Tech: Setup, Repairs and Mods 2 04-14-2003 11:13 PM
Edge bridge setup jetfixer Tech: Setup, Repairs and Mods 1 08-29-2002 07:28 PM
