Tech: Setup, Repairs and Mods
edge, lo pro and edge pro are 100% drop in fit
Page 1 of 4
09-02-2005, 10:26 AM
dex
Posts: 1,972 - iTrader: (
Edge pro route will not accommodate an edge or lo pro
As most people don't read full threads I'm editing this to re-cap
Edge equiped guitars will accommodate Lo-pro without mods.
Lo pro jems will accommodate an
Edge trem
, Lo pro RG's and JS will NOT accommodate an Edge as the bolts at the rear of an Edge are sticking out too far
Edge Pro guitars will not accommodate Edge or Lo pro trems
That's pretty much it.
ilia
p.s. not sure if accommodate works - couldn't think of a word that kind of means "fit" but in the other way.
E.g. Lo pro will fit in an Edge routed guitar without mods and Edge equiped guitars will accommodate Lo-pro without mods.
p.p.s
Here's the pics that show the route/posts were not moved.
When I took those and posted the original thread I was under the impression that post position (not spacing) was the biggest issue but as you can see from the red marked photo the trem route and the short Edge Pro ears are really to blame.
I'm not sure if this is the only issue or if there are other things in the way but I'd be willing to file 2-3mm of Lo Pro ears to see if it can be shoehorned into an Edge pro guitar.
Chancess of me owning one any time soon are slim though so hopefully someone else will try it.
10:52 AM
dex
Find all posts by dex
09-02-2005, 10:32 AM
fettouhi
Posts: 9,937 - iTrader: (
Re: edge, lo pro and edge pro are 100% drop in fit
Well done
and many thanks.
Regards
André
fettouhi
Find all posts by fettouhi
09-02-2005, 12:55 PM
screamndemon69
Posts: 5,676 - iTrader: (
i believe (and Rich will surely post his findings) that the cavity routes are different from Lo-Pro and Edge to Edge Pro. i didn't know there was any worry of post spacing? the neck specs haven't changed in the width of the fretboards so the spacing wasn't really the problem. i might be missing the point of your post all together.
it sucks the routes for the trems are different as they aren't selling
Edge Pros
yet.
i personally haven't had ANY issues with my non-locking posts as everyone is worried about though - sorry Rich. my '04 Jem7VWH has just as much stability as my other guitars that do have the post locks. i have to say i don't have a Peterson strobe but i use a Sabine 1100 and i haven't had any stability problems show up on it. i could be the odd-man out with this one though. just my 2cents.
TJ
screamndemon69
Find all posts by screamndemon69
09-02-2005, 01:05 PM
dex
Yeah my friend - you are missing the point.
For 2 and a half years people here have claimed (all because of one chat someone had with a clueless rep) that the trem has been redesigned so much that the posts had to be moved back to acomodate for the new saddle design.
Well here it is - posts are in the same spot and edge, lo pro and edge pro have same routes and same dimensions which means you can replace them with each other - much like edge and lo pro are 100% compatible, the edge pro is part of that group and that means you can just drop in an edge pro into 1987 5xx RG as well as drop an Edge into a 2005 jem.
There.
Ok, I'm going to the pub now so the pics won't work until monday - hopefully someone saved them somewhere and would upload them somewhere else with a link here.
ilia
dex
09-02-2005, 01:19 PM
EKG
Posts: 2,280 - iTrader: (
I am not sure it was the posts that were the issue. Wasn't it something about the knife edges, intonation,
spring cavity
and trem routes? The only new ones I've seen were at NAMM, so I am no expert on the new trems.
EKG
Visit EKG's homepage!
Find all posts by EKG
09-02-2005, 01:20 PM
screamndemon69
dex
There.
ilia
i haven't pulled my trem from my '04 7VWH yet but i lined it up with a Lo Pro and upon a visual inspection the posts seemed to match but the block and routes are different sizes.
i see where you are goin with the posts but i will still need to confirm the Edge Pro route to Edge or lo Pro possibilty. Rich has had the chance to try it i'm sure and two weeks ago when i talked to him about the possibility he said w/out re-routing the cavity - it can't be done.
again, i haven't tried it yet but i would love it if i could put a Lo Pro or Edge in my Edge Pro equiped Jem. my fingers are crossed but i am not holding my breath.
i don't have any issues with the Edge Pro (plays great), i would just like to be anal and keep the gold from looking like crap.
screamndemon69
09-02-2005, 01:29 PM
jemsite
Administrator
Posts: 9,259 - iTrader: (
those photos are unavailable. i'd like to see them.
it wasn't a stud/spacing issue i was lead to believe the trem would fit but not INTONATE.
i personally have avoided the new trems like the plague and have no retrofitting experience... glen
jemsite
Find all posts by jemsite
09-02-2005, 01:34 PM
screamndemon69
thinking about this from a company point of view - it wouldn't be a wise choice to have any spacing that would cause a change in neck specs (ie: wider or narrower neck) so i'd figure these things wouldn't change w/out causing my issues in production problems but more importantly with the consumer, changing the specs on necks that made Ibanez a choice guitar to play over countless others.
screamndemon69
09-02-2005, 01:55 PM
fettouhi
James reported a few months about a direct swap of a Edge Pro and a Lo
Pro Edge
, so that would support dex's findings/conclusions.
Regards
André
fettouhi
09-02-2005, 01:58 PM
screamndemon69
if that's the case, i'm kinda bummed right now as i just sold/traded of a new chrome Lo Pro Edge that i'd really wanted to drop into my '04 Jem.
if this is true, i am very happy as i will get my mits on another one - probably black this time though
thanks Andre!
screamndemon69
09-02-2005, 03:11 PM
fettouhi
screamndemon69
thanks Andre!
Here is the thread where James mentions it
http://www.jemsite.com/forums/showthread.php?t=36286
look at the last post on page 1
Regards
André
fettouhi
09-02-2005, 03:13 PM
Dr Mindcrime
Posts: 88 - iTrader: (
The routes are different, I already tried to put a lo-pro in my 04' js1200.... the body needs to be routed out quite a bit for it to plop in. Thats as far as I went with it... Im better off painting a 2002 Js1000
candy apple red
if I wanted an edge/lo-pro equipped js1200.
Dr Mindcrime
Find all posts by Dr Mindcrime
09-02-2005, 04:05 PM
screamndemon69
i noticed the spot where they didn't line up in the route was at the front edges where they are angled more steeply for the edge pro and the lo pro is more flat across.
i read the older thread you linked us to and Rich stated that there are intonation issues that are unfixable. why 7 Dying trees didn't have these issues is still unexplained. i am biased to listen to Rich's comments due to the amount of Ibanez trems he deals with and has for many years. he knows these things as well or better than most techs will ever know just for the fact that he goes thru such extensive extremes when setting up and doing maintenance. how many techs take the whole guitar apart - especially a new one?
screamndemon69
09-02-2005, 05:03 PM
fettouhi
So this remains unresolved then.
Regards
André
fettouhi
09-02-2005, 06:36 PM
Dr Mindcrime
fettouhi
Regards
André
Until somone routes the edge pro guitar and moves the
trem studs
up a few mm, i guess so....
chris
Dr Mindcrime
Page 1 of 4
bridge pickup
bridge pickups
bridge pup
candy apple red
edge pro trem
edge pro tremolo
edge pros
edge trem
edge trems
ibanez backstop
ibanez edge pro
ibanez guitars
ibanez jcrg
ibanez trem
neck pickup
pro edge
pro tremolo
scale lengths
spring cavity
trem studs
will edge zero pro fit edge 3 route?
how do drop d on a tuner
how to set up a edge 3?
06:50 AM
