Tech: Setup, Repairs and Mods
edge lo pro - how to insert the string lock blocks
05-24-2007, 07:57 AM
new_breed
Posts: 9 - iTrader: (
Hey
I´m in the process of changing all the
string lock
blocks (THEY ALL CRACKED!) but i can´t remember how they are supposed to be put in.
The block has a sort oval shape with the round hole more to one side than the other....SO is the side with the hole supposed to be up or down?
Quick answear please
new_breed
Find all posts by new_breed
05-24-2007, 08:42 AM
nuno
Posts: 4,725 - iTrader: (
Re: edge lo pro - how to insert the string lock blocks
the hole must be faced toward the fine-tuners (the locking screw will rock against the hole). and the lock block must be flipped so that the hole would sit near the bottom side of the saddle. hopefully it's clear enough.
ps: do not overtighten the lock screws. it won't ensure the string to be locked to the saddle. a little tight is enough.
nuno
Visit nuno's homepage!
Find all posts by nuno
05-24-2007, 01:08 PM
new_breed
Thank you!
I bought the guitar used, = The previus owner cracked the blocks:/
But now i have 7 new
new_breed
02-01-2011, 01:27 AM
AJAzure
Posts: 5 - iTrader: (
hey guys,
A block dropped out and I need to pop it back in. How exactly do these go in? Diagram please? Thanks!
AJAzure
Find all posts by AJAzure
02-01-2011, 01:38 AM
AlaskaBat
Contributor
Posts: 6,645 - iTrader: (
Reviews: 94
AJAzure
hey guys,
Read the above replies. No diagram is needed. Put the block in with the dimple on the bottom end and facing the string block screw. The screw engages the dimple for a secure fit.
AlaskaBat
Visit AlaskaBat's homepage!
Find all posts by AlaskaBat
02-01-2011, 02:24 AM
AJAzure
OK I believe I did it right. Hole connecting with screw. When putting in a string and then tightening the screw towards the block, the block still moves. The screw moves with no issues. That's why I was thinking it's in wrong. What am I missing? Thanks.
AJAzure
02-01-2011, 02:52 AM
AlaskaBat
Contributor
Reviews: 94
Are we being punked here??? The block is supposed to move when you tighten the screw. Then the block makes contact with the string, tighten a little more--that's what locks the string in. The string end is supposed to be sandwiched between the front inside of the sadle and the block.
I guess you need a few videos of how to change strings on a double locking trem:
http://m.youtube.com/index?desktop_u...&v=s_qLi_cWQLc
http://m.youtube.com/index?desktop_u...&v=gulUAn5GAZM
03:01 AM
AlaskaBat
02-01-2011, 08:41 PM
AJAzure
No punking. Seriously that's how you get punked?
I've been working with floyd type bridges for 20 years. I could have made such a video. your links fail btw.
Rather than assumption and flip answers, you might try being constructive.
When I screw the locking screw all the way the string end pushes the block back even if it looks like the block and the screw are all the way. So either the block is in wrong or...
It seems like a problem that shouldn't exist so thus my being baffled. I've ever seen this happen.
I will pull the block and double check that it goes in correctly. If it still moves and all is in place..I'd love to hear constructive thoughts on why.
AJAzure
02-02-2011, 01:08 AM
AJAzure
fixed somehow.
AJAzure
AJAzure
fixed it somehow. thanks for the help.
AJAzure
02-02-2011, 01:15 AM
AlaskaBat
Contributor
Reviews: 94
AJAzure
We were trying to be constructive, but your lack of details really made it seem like you couldn't figure out why the block moved when you moved the screw--look at it from that perspective. You know what you mean, but all we have to go on, is what you write.
AlaskaBat
02-02-2011, 01:16 AM
AlaskaBat
Contributor
Reviews: 94
AJAzure
Post what you did, so the next person that has the same problem knows what to look for.
AlaskaBat
string lock
how to "edge zero" string chang
how to fix string buzz ibanez lock nut
use a .016 for the 2nd string?
Edge mysteries solved!!......? - Answers to some common ques
Jason Stone
09:35 AM
Your string guages are wrong!
Dino
Gear and Equipment
238
05-05-2008
07:34 PM
MyHELP lack of good string muting is KILLLING ME!! - Fret ha
Triangle
Guitar Lessons & Music Theory
08:57 AM
A saddle in the lo-pro edge rattles...? - Help, B string sad
darthpolster
06:09 AM
String tension on Edge - It shouldn't change when bent? Impo
YngVaiTriani
05:57 PM
09:08 AM
