Tech: Setup, Repairs and Mods
Edge/Lo Pro metal - Type of metal?
10-09-2001, 11:28 PM
YngVaiTriani
Posts: 548 - iTrader: (
I've noticed the metal made with
TRS trems
is really crappy. Strings put grooves in them no problem not to mention the intonation screwed. Just all eaten up.
Now the Edge systems... are they made with steel like that high quality fender trems?
I think the TRS is some kinda crappy die cast iron or something.
...and the gold on 7VWH... is that gold plating???
YngVaiTriani
Find all posts by YngVaiTriani
10-09-2001, 11:53 PM
Kevan
deleted username
Posts: 1,429 - iTrader: (
Edge/Lo Pro metal
Ironically, the TRS trems are actually STRONGER than the LoPro's. *Try a dent-test next time you have two lying around. *:-)
The quality of the metal used in Edge and LoPro trems meets or exceeds anything else out there.
Kevan
Find all posts by Kevan
10-09-2001, 11:59 PM
Posts: 19,352 - iTrader: (
Edge/Lo Pro metal
Don't try the dent test on the LPE or Edge, the base is spelter (pot metal) and will crack very easy, but you can wail away on the TRS base if you want.
10-10-2001, 12:02 AM
YngVaiTriani
Edge/Lo Pro metal
Naw man... TRS is not stronger at all. My Lo-TRS II is all eaten at the saddles and intonation screws. The Edges are also bigger and heavier. I would really really doubt TRS is stronger. Strings put lines in the so fast.
How could Edges not be steel?
YngVaiTriani
10-10-2001, 12:10 AM
Edge/Lo Pro metal
I can't compare the saddles on each, but everything about the TRS is cheaper. It's much cheaper to stamp a piece of sheet steel than it is to cast spelter.
10-10-2001, 12:17 AM
YngVaiTriani
Edge/Lo Pro metal
How you know all this stuff Rich? Dang...
Spelter?
Thanks a bunch.
YngVaiTriani
10-10-2001, 12:19 AM
Edge/Lo Pro metal
I've got 2 broken base plates right here
10-10-2001, 12:33 AM
YngVaiTriani
Edge/Lo Pro metal
Holy cow! 2?!
Edge/LPE baseplates?!
But their so darn thick!
The trem seems invincible to me. I won't be doing anything to it other than play and adjust.
YngVaiTriani
10-10-2001, 12:39 AM
Edge/Lo Pro metal
1 6, 1 7, both LPE's. Like I said, spelter cracks easy, these were both stress fractures from shock alone.
10-10-2001, 01:30 AM
RSVampire
Posts: 1,813 - iTrader: (
Edge/Lo Pro metal
what did you replace them with Rich?
RSVampire
Visit RSVampire's homepage!
Find all posts by RSVampire
10-10-2001, 01:35 AM
Edge/Lo Pro metal
The 6 is just junk now, still usable because the break is one of the points in front of the knife, but who want a trem with a busted plate? Luckily
Frank Falbo
had a spare 7 plate he sold me so that went back into service
10-10-2001, 03:52 AM
rickboot
Posts: 332 - iTrader: (
Edge/Lo Pro metal
I like the aesthetics and the feel of the Edge and Lo Pro trems, but the metal is soft and the plating is poor. Take a Dremel tool to one sometime and you'll see what I mean.
Rick
rickboot
Find all posts by rickboot
10-10-2001, 04:02 AM
Edge/Lo Pro metal
Actually the chrome is extremely durable. The cosmo is vunerable to get the "look", but the gold could definately be a little thicker....
10-10-2001, 05:42 AM
rvj
Posts: 602 - iTrader: (
Edge/Lo Pro metal
The gold on my 7VWH started to wear after only 2 weeks!
rvj
Find all posts by rvj
10-10-2001, 07:01 PM
UVmanMike
Posts: 128 - iTrader: (
Edge/Lo Pro metal
Funny, the cosmo lo pro on my mint UV777GR has already started pitting, but the lo pro (black) in my RG7620 that I've had for 3 years is perfect. And believe you me, the RG gets alot more abuse and sweat on it's trem.....
UVmanMike
Find all posts by UVmanMike
base plate
frank falbo
lopro trem
trs trems
what ibanez guitar had a fender type headstock
what metal is edge 3 tremolo made out of
how to play heavy metal thru single coil?
best cab for metal?
11:15 PM
