Old 03-09-2008, 02:01 PM
martyfriedman86  is offline
Posts: 155  -  iTrader: (0)
Edge Locking studs help
Hi everyone
I just got a nice RG from 1993 with an edge (i beleive it's a 470)
it plays beautifully
But it came with no locking studs.
I mean, theres is hole in each of the trem posts, but they're both empty. I beleive the previous owner removed them for some reason.
Could anyone give me the specifications and measures of this screws so that i have someone do them for me?
Thanks a lot!
I promise pictures once it's ready
Old 03-09-2008, 02:16 PM
Rich  is offline
Posts: 19,350  -  iTrader: (21)
Re: Edge Locking studs help
They're in there.
Old 03-09-2008, 02:33 PM
Originally Posted by Rich View Post
They're in there.
Sorry, I didn't understand
What's in there? The screws?
I'm trying with all my allen wrenches and they all go deep inside but none of it seems to fit into the head of any kind of screw
Old 03-09-2008, 02:35 PM
Rich  is offline
1.5mm
Old 03-09-2008, 02:57 PM
RG462  is offline
Posts: 507  -  iTrader: (0)
lol. Spoken by a pro
Old 03-09-2008, 03:27 PM
yep.
i'll have to wait until tomorrow to but an 1.5mm allen wrench
i've only got 1mm and 2mm
Old 03-09-2008, 09:39 PM
Question
help needed once agaaaaaain
Found the screws
they were pretty stucked in
put some wd40 and one loosened but the other one didn't
and the allen head is kind of rounded :S
what should I do
Old 03-09-2008, 10:16 PM
CosmicDebris  is offline
Posts: 3,216  -  iTrader: (4)
Back off on the main studs first. That will take off the pressure of the littles have on them and make it easier to get them out of loose.
Old 03-09-2008, 10:45 PM
I'll try then..
But what should I do with the rounded head?
the allen wrench almost slips inside it...
Old 03-09-2008, 11:17 PM
Ayrton  is offline
Back the main stud completely out and you should have a bit of the inner stud sticking out the bottom that you can then grasp and remove.
Old 03-09-2008, 11:25 PM
thanks a lot
i guess i'll have to get new screws then?
is there any place you can order them or something similar?
Old 03-09-2008, 11:37 PM
Rich  is offline
Get a new wrench, there's no way you stripped the head using a 1.5
Old 03-09-2008, 11:39 PM
i hope so
that's really good news
i'll let you know tomorrow.
thanks for everything
Old 03-10-2008, 02:28 AM
DarthLamer  is offline
Posts: 108  -  iTrader: (0)
Re: help needed once agaaaaaain
Originally Posted by martyfriedman86 View Post
Found the screws
what should I do
If the screws are not exposed, leave them be. As I've stated before, locking studs are all hype. With having the tension on the springs adjusted properly, there is *no* apparent benefit in utilizing locking studs.
Old 03-10-2008, 02:55 AM
Rich  is offline
Please stop stating it because it's false. Locking studs have been a benefit to tuning return for 20 years. One of the biggest causes of instability is loose stud inserts, which can cause wild swings in instability, and loose studs are the same problem, just on a smaller level.
allen wrench, allen wrenches, edge trem, edge trems, ibanez edge trem, intonation tool, locking stud, locking studs
locking studs on an edge pro? champ222 Tech: Setup, Repairs and Mods 2 02-13-2006 10:41 AM
Edge Pro Locking Stud Mod? Darren Wonnacott Tech: Setup, Repairs and Mods 7 08-18-2005 09:14 PM
Adjusting String Action with locking Studs. ToneRanger Tech: Setup, Repairs and Mods 5 04-28-2005 02:08 AM
Can the pivot studs of the edge pro be swapped out JuanCaca Other Ibanez Guitars (including Premiums) 4 11-08-2004 05:02 PM
cracks around anchor studs on edge trem MERCYFULFATE J-Custom, USA Custom & Prestige Ibanez Guitars 1 06-18-2003 02:31 PM
