Tech: Setup, Repairs and Mods
EDGE long block - wich years? wich models?
08-01-2006, 12:07 AM
jlander
Posts: 77 - iTrader: (
ive recently installed an used
EDGE trem
on my RG270 (some routing needed), and ive noticed that the block is longer than the other trems i`ve saw... and i know the 570 have the edge trem (and the same body dimensions that the 270), so wich years where they produced and in wich models came??? JS? S?
thanks
jlander
Find all posts by jlander
08-01-2006, 12:13 AM
djohns74
Posts: 580 - iTrader: (
Re: EDGE long block - wich years? wich models?
I've heard that the Roadstar from the mid-80s used a non-recessed Edge, which necessitated the longer block. I've got one of these Edges too, and in chrome to boot, which strikes me as double rare.
djohns74
Find all posts by djohns74
08-01-2006, 12:22 AM
LonePhantom
Posts: 5,369 - iTrader: (
Reviews: 98
Yeah I've installed one of these, an 87 version on my '95 RG470.
The
trem arm holder
is not recessed on the early versions too.
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
08-01-2006, 12:25 AM
sniperfrommars1
Posts: 3,302 - iTrader: (
What your noticing is the fact that your 270 has a different depth, it DOES NOT have the same routing at all, its in fact even smaller than a japanese version of the same guitar, all around. The Js and s have a smaller edge block on them correct me if im wrong.
sniperfrommars1
Find all posts by sniperfrommars1
08-01-2006, 01:21 AM
djohns74
sniperfrommars1
Different routing technically, yes, but the body dimensions on a 270 are essentially identical to a Japanese counterpart. The depth of the trem cavity, in this instance, is irrelevant since either way, the saddles of the trem have to sit at the same height relative to the top of the body, and thus the
trem block
would reach down to exactly the same depth on either body. Believe it or not, the trem block is actually longer on Edges that were meant for non-recessed bodies.
djohns74
08-01-2006, 02:14 AM
sniperfrommars1
djohns74
Different routing technically, yes, but the body dimensions on a 270 are essentially identical to a Japanese counterpart. The depth of the trem cavity, in this instance, is irrelevant since either way, the saddles of the trem have to sit at the same height relative to the top of the body, and thus the trem block would reach down to exactly the same depth on either body. Believe it or not, the trem block is actually longer on Edges that were meant for non-recessed bodies.
The bodys are roughly the same shape but the dimensions are quite different imo.
sniperfrommars1
08-01-2006, 04:14 AM
nuno
Posts: 4,725 - iTrader: (
the RG270 is thinner than a Japanese RG. IIRC it's 40mm vs 43mm. i've got both and i noticed it immediately. anyway, yes, non-recessed Edges had a longer block and arm-insert. i also think there are three types of block, as you can see below:
it reads:
S
block: 540R
HS
block: 540S
HV
block: JEM, UV
nuno
Visit nuno's homepage!
Find all posts by nuno
08-01-2006, 04:28 AM
Posts: 19,352 - iTrader: (
I've never seen a block cast HV. H, S, and HS are the 3 castings you'll see, and all JEM, UV, JS's, RG's all have HS blocks which are the shortest block they make. The long blocks from the non recessed versions aren't cast with a code, but their part number is EDGE 15.
08-02-2006, 12:14 AM
jlander
so, we can say its an 80`s EDGE... it may be, its not in the best condition... but the Ibanez and Edge logo is the same... let me check the ibanez catalogs at richs website
ill post some pics soon...
jlander
08-02-2006, 01:25 PM
jlander
ok, i don thave the pics, but the measures are 50x40x6 mm (only the block) iwch ones are the ones in the other EDGE (not lo
pro edge
) blocks??
thanks
jlander
08-02-2006, 03:36 PM
marianozz
Posts: 2,221 - iTrader: (
Interesting, i have an '87 Radius with an Edge with a screw in bar holder (not sure thats original anyway), no
retaining bar
for the springs... but the body is "a lil" recessed nowhere near as deep as my RG...
I was thinking about filling the cavity, and leave the trem flush to the body... but now im not so sure, if im gonna need a longer block then its a no-no.... :/
marianozz
Find all posts by marianozz
arm holder
edge trem
ibanez catalog
pro edge
retaining bar
trem arm
trem arm holder
trem block
sight reading ABRSM how long look through
how long ear ringing concert
when will ibanez 2010 models go on sale
Edge mysteries solved!!......? - Answers to some common ques
Jason Stone
09:35 AM
RG 270 w/ maple fingerboard.. wich years were they made in??
jlander
06:16 PM
New Edge III bridge in JS models??
chemicalmagical
05:13 AM
edge spring block lock, does it affect tuning stability
satchman
10:21 PM
S-Series - Any new models with Edge or LoPro?
Coolstu
Gear and Equipment
11:15 PM
07:25 AM
