Old 04-26-2006, 07:54 PM
jsdisciple  is offline
Posts: 282  -  iTrader: (0)
Edge pro eating bushes
Hi all i have only owned my rg 2550e a few days
and noticed the whammy bar bushes need replaces already
the bar does not stay in one place it always fall down
making it hard to make the cricket sound or warble like mr steve vai does
just wanted to know if there is any tech fixes available
i'am not a heavy whammy bar user so this makes me think there is and adjustment somewhere
any help will be awesome
thanks jsdisciple
Old 04-26-2006, 08:09 PM
moro  is offline
Posts: 623  -  iTrader: (2)
Re: Edge pro eating bushes
Remove the bushing, apply a thin layer of clear nail polish in the grooves, then replace the bushings when the nail polish is dry. If the bar is still loose, apply more nail polish.
If that doesn't help, the bushings may be so worn down that you just need to get new ones. They're cheap. Try ibanezrules.com
Another possibility is that you're not pushing the bar in far enough. It can be really snug on a new tremolo. Are you pushing it in far enough that it clicks into place?
Old 04-26-2006, 08:27 PM
Thanks moro for your fast reply
i have changed the bushes supplied with the guitar
and the bar is still very sloppy
i have made sure the clicks into place,
thanks for tip using nail varnish, i can see what you mean by it
the varnish will make the bushes stand out more
is there and adjustment from the trem cavity for the whammy bar!!
thanks jsdisciple
Old 04-30-2006, 12:13 PM
ScottB  is offline
Posts: 2,208  -  iTrader: (12)
Images: 8
The nut that holds the arm barrel to the bridge may be loose. You can tighten the barrel nut with a 10mm deep-well socket wrench.
Old 04-30-2006, 12:41 PM
JESTER700  is offline
Posts: 2,234  -  iTrader: (0)
I saw the title and thought there'd be an off-color joke in there...
Old 04-30-2006, 01:27 PM
Demiurge  is offline
Posts: 883  -  iTrader: (7)
If it were true, then it wouldn't be too hard to convince my gf to let me buy another guitar...
Old 05-02-2006, 06:46 AM
themaidenmaniac  is offline
Posts: 379  -  iTrader: (0)
Dont worry, its not you dude. Its the crappy ibanez trem design- ive just let mine go loose now haha. Gave up on that battle
Old 05-02-2006, 07:07 AM
Shredder87  is offline
Posts: 417  -  iTrader: (0)
Yeah, I've found that on my 5 month-old RG2550. It's pretty irritating. I just learned to live with it.
Old 05-02-2006, 08:20 AM
markg5150  is offline
Posts: 2,361  -  iTrader: (2)
Easiest, cheapest solution is use a small disc of plastic from a Daddario string bag, bank money bag etc. Hold the disc over the hole in the bridge and push the bar in.
Nice tight fit and lasts for ages
Old 05-02-2006, 10:58 AM
eviltwin  is offline
Posts: 1,629  -  iTrader: (0)
Images: 6
You guys must be doing something wrong, the trem cannot be at fault here.
I've changed the bushings on my HAM (LoPro not EdgePro) on September 13th (just checked the receipt, still in the case) Now, I am a heavy trem (ab-)user, and it still stays up.
I can feel the bushings have worn slighly, but at this rate it will probalby last me another 6 months or so.
One caveat, my guitar is on a stand and doesn't go out much, ergo the bar stays in, perhaps you should take more care in removing/installing the trem. Also make sure the bushings (washers) are installed correctly:
http://www.jemsite.com/forums/showth...hlight=washers
(there must be a dozen other threads on this..)
Old 05-02-2006, 11:23 AM
southpaw_lefty  is offline
Posts: 1,140  -  iTrader: (3)
Maybe the edge pro enjoys eating bushes.
Old 05-09-2006, 09:38 AM
guitarslinger213  is offline
Posts: 375  -  iTrader: (1)
clear nail polish trick is the end all solution. The trick is to let it dry overnight. I know it sounds crazy, but it works better if you let it dry overnight.
You can always retro fit a schaller stlye bar to it.
Old 05-09-2006, 10:39 AM
nickcoumbe  is offline
Posts: 2,417  -  iTrader: (0)
Reviews: 34
I prefer a whiskerless kitten.
Seriously dudes, if your guitar is eating bushes then don't take it in the garden.
I am actually with eviltwin on this one. The bushes need adjusting the more you remove the bar.
Old 05-09-2006, 10:53 AM
Shredcows  is offline
Posts: 506  -  iTrader: (1)
You can swap the Edge arm system for a Schaller/OFR arm system. Its been done many times, I've done it to my Edge, and to a few other Edge/Edge Pro systems.
Old 05-09-2006, 11:18 PM
ScottB  is offline
Images: 8
Just tighten the nut on the underside of the bridge.
Better yet, remove the nut, apply nail polish to the threads on the arm barrel and then put the nut back on.
Trust me. The barrel is loose and is rotating in the bridgeplate.
arm holder, ebmm petrucci, fender deluxe, ibanez trem, steve vai, trem arm, trem studs
Edge III swap for another Edge model trem? lespaulreedsmith Other Ibanez Guitars (including Premiums) 36 03-14-2009 06:10 PM
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
I just put an Edge in my RG470! DirtyBird31 Tech: Setup, Repairs and Mods 10 09-14-2007 12:22 AM
edge, lo pro and edge pro are 100% drop in fit dex Tech: Setup, Repairs and Mods 47 10-18-2005 12:29 PM
lo pro edge vs edge pro 7 cakewalkr7 Tech: Setup, Repairs and Mods 4 02-11-2005 12:23 AM
