Old 03-22-2009, 09:18 AM
DanEwins  is offline
Posts: 31  -  iTrader: (0)
edge pro problem. help?
I have a minor problem with the edge pro on my JS1200. The fine tuner on the bridge for the D string will not tighten the string only loosen it. as a result, i need to undo the lock on the neck every time i go slightly out of tune (usually from being too aggressive with the whammy bar :P ). this is really annoying and i was wondering if anyone knows what to do..
cheers, Dan
Old 03-22-2009, 01:40 PM
Rich  is offline
Posts: 19,350  -  iTrader: (21)
Re: edge pro problem. help?
The saddle tailpiece is in the spring plate the way it should be?
edge pro, fine tuners, floating bridge
Lo-Pro Edge Problem v1ncent1993 Tech: Setup, Repairs and Mods 11 08-26-2008 05:24 AM
a little problem with edge II mr.jem555 Tech: Setup, Repairs and Mods 1 06-10-2007 09:27 PM
Edge Problem 560licious Other Ibanez Guitars (including Premiums) 2 03-23-2007 10:54 AM
Lo pro edge & Double Edge in tune problem Raffel Tech: Setup, Repairs and Mods 21 05-14-2004 09:59 AM
Wierd Lo-Pro Edge 7 problem... big problem! Jupiter Tech: Setup, Repairs and Mods 5 06-11-2003 02:43 PM
