Old 03-09-2009, 09:48 AM
valcian  is offline
Posts: 37  -  iTrader: (0)
Edge Pro Problem (not pulling up properly)
Hi, just wondering if anyone can help me with this, it's happened before but I had a tech fix it and now that it's happened again I figure I'd like to know how to sort it myself.
When I pull up on the bar on my Edge Pro (in an rg1570) the pitch raises (as it should) but the block of the trem hits the body / edge of the cavity before the bottom edge of the trem can hit the foam lined cavity where it's supposed to go.
I've looked at my trem angle and it seems okay, and raising the action doesn't seem to help.
Pulling up from the open low E I get about 8 semitones of pitch increase (equivalent to the 8th fret pitch).
If anyone knows what to do about this I'd very much appreciate it.
Thanks in advance,
Valcian
Old 03-09-2009, 10:32 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
Re: Edge Pro Problem (not pulling up properly)
...and you haven't enough yet!?! man, stop there, don't go further. anyway, it's not necessary for the bottom edge of the trem to hit the foam pad. also, raising the action will raise bottom of the trem even far from the pad. if you want the tail to touch the pad, you have to lower the action, instead. but really, you're going already too far with that pull-up, pal.
Old 03-09-2009, 10:44 AM
valcian  is offline
When I wrote it I did think "yeah, that's actually quite alot of pull up". But I've just had another look and although the low E pitch raises by around 8 semitones, the high E only raises by 3 (3 frets) which really isn't much at all.. hmm..
I've lowered the action back down, but that doesn't help at all..
Old 03-09-2009, 11:57 AM
nuno  is offline
the high E only raises by 3 (3 frets) which really isn't much at all.. hmm...
that's even too much for a high-E. don't ask too much from your guitar.
it doesn't help because it's not the action height that guarantees you a wider pull range. because no matter whether the trem is set high or low, it will always be the same distance from the cavity, as it moves (the trem, that is) vertically, not horizontally. i told you if you want the bottom of the trem tail to hit the foam pad, then lower the action until it does. but it makes no sense actually, because you're limitating the pull range even more. the "problem" is the trem block hitting the cavity during pull-ups. you "should" route the cavity out of a few millimeters, so that the spring block wont hit it when pull the bar any longer.
but really, 8 semitones on the low-E is even too much. live with it.
Old 03-09-2009, 12:27 PM
valcian  is offline
Well the trem always used to hit the foam lined cavity, suggesting something is out of whack now, I also used to get more than 3 frets pitch raise from the high E, the strings used to fret out before the trem hit the foam lined cavity.
I wouldn't call it asking too much, I'd call it wanting things back as they were :P
Old 03-09-2009, 12:50 PM
Jem7RB MK  is offline
Posts: 2,341  -  iTrader: (20)
Although i am kinda with Nuno on the fact that, you have PLENTY of travel, if you used to get more and now you dont, your studs have shifted, as the trem route wont have moved, neither will the trem block have distorted, only result i can think of, is trem studs moving/shifting forwards. if thats the case, it'll get worse and you'll have a hefty repair bill.
Regards
Rob
Oh, i just thought, are you using a higher gauge string set? the only other variable is you "thought" it raised more.
Old 03-09-2009, 12:57 PM
valcian  is offline
I'm using d'addario 9s as always, idk 3 frets worth of pitch raise on the high E just doesn't strike me as alot.. The edge of the trem used to hit the foam lined cavity and now it doesn't, that's the real problem here, the idea of the posts shifting worried me though :P
Old 03-09-2009, 01:05 PM
honestly, it's all i can think of
Rob
Old 03-09-2009, 01:10 PM
valcian  is offline
Not good As I said, it's happened before and a tech fixed it, but didn't really tell me what was wrong, other than "the posts had dropped into the body a bit" the rg1570 doesn't have locking studs so idk if it's something to do with that.. I'm just hoping whatever it is it's not serious :P
Old 03-09-2009, 01:18 PM
are you able to take some pics of the posts ? non locking studs maybe the key ?
Rob
Old 03-09-2009, 01:21 PM
Rich  is offline
The only way you hit the pad first is if the action is very low. The arm holder hitting in the cavity is the limit of travel on an EP. If your arm holder is loose and has turned and now the spring is hitting first might be the reason, if your arm holder isn't loose, it isn't.
valcian  is offline
Yeah, I'll take some pics in a minute, I'll do pics of the trem from the side, back (with the rear plate off) and show where it's pulling up to, just for the sake of completeness :P.
Old 03-09-2009, 02:05 PM
valcian  is offline
Noo, my post count isn't high enough to post images or links.. I'll pm you the links Rob
Old 03-09-2009, 02:43 PM
valcian  is offline
sent you them aswell rich, just to be sure :P
Old 03-09-2009, 03:53 PM
hmmm, i looked and see nothing majorly wrong tbh, i'll let Rich comment (he'll be far better and diagnosing the prob) but he might take a few hours, he's normally really busy even when not selling stock
It just looks like the end of it's travel
Rob
edge pro pull up cavity
how do i sweep properly jem_fanatic Guitar Lessons & Music Theory 15 01-16-2007 10:51 PM
Pulling sharp with edge pro tremolo jalguitarman Tech: Setup, Repairs and Mods 10 02-22-2006 03:07 AM
Pulling the Double Edge horstausmforst Tech: Setup, Repairs and Mods 3 09-17-2003 01:43 PM
Wierd Lo-Pro Edge 7 problem... big problem! Jupiter Tech: Setup, Repairs and Mods 5 06-11-2003 02:43 PM
Chorus. How to use it properly? microdmitry Gear and Equipment 15 03-09-2003 02:00 PM
