Tech: Setup, Repairs and Mods
Edge Pro Strings to tight
06-26-2005, 05:22 PM
Led_Fingers
Posts: 20 - iTrader: (
Hi, I have an RG 2550E with an
Edge Pro trem
. The problem Im having is that the strings are to tight. I have three springs in the normal configuration( parallel to each other). The bridge angle is just about right, parallel with the body, and Im using D'Addario 9-42
gauge strings
. So basically when I tune it up to pitch and the bridge is at the right angle the strings tighten to the point where I can only bend them about a half step.
I would really appreciate any help, ask me if you need more info, thanks.
Led_Fingers
Find all posts by Led_Fingers
06-26-2005, 05:35 PM
elcid
Posts: 8,719 - iTrader: (
Re: Edge Pro Strings to tight
Have you tried removing one of the springs and tightening the claw to the body?
Or maybe stop being a girl
elcid
Find all posts by elcid
06-26-2005, 05:38 PM
dimitar
Posts: 487 - iTrader: (
Led_Fingers
Hi, I have an RG 2550E with an Edge Pro trem. The problem Im having is that the strings are to tight. I have three springs in the normal configuration( parallel to each other). The
bridge angle
is just about right, parallel with the body, and Im using D'Addario 9-42 gauge strings. So basically when I tune it up to pitch and the bridge is at the right angle the strings tighten to the point where I can only bend them about a half step.
I have the same guitar- brand New and I have to setting up the trust rod!
Pls send some photos of EDGE and strings and Neck!!!
Regards
Dimitar
dimitar
Visit dimitar's homepage!
Find all posts by dimitar
06-26-2005, 05:57 PM
elcid
Actually is it brand new?
If so maybe try really using the whammy bar a bit and see if that brakes the springs in a little.
elcid
06-26-2005, 06:17 PM
miker
Posts: 37 - iTrader: (
Doesn't matter if you have a hard tail or a floating trem... if the neck length is the same (i.e., say the same guitar with two bridge types), the tension on a given gauge of strings is the same when the strings are tuned to perfect pitch using a tuner.
So, use a tuner... else, post some pictures. Not sure what you're talking about really. Sorry.
miker
Find all posts by miker
06-26-2005, 06:19 PM
Led_Fingers
Well its about 3 weeks breaking it in now, it felt fine when I first played it( with the strings Ibanez put in) but now that I put in these new strings it is way to tight, like they could break if I were to bend them a a whole step.
Led_Fingers
06-26-2005, 06:20 PM
Led_Fingers
Also, now the springs seem tighterwhen I depress the bar.
Led_Fingers
06-26-2005, 06:26 PM
dimitar
Led_Fingers
This is a neck problem!!! Today I'v setting up main and it seems more correctly now...
dimitar
Led_Fingers
I'll post some pics in about 10 mins
Led_Fingers
06-26-2005, 07:05 PM
Led_Fingers
here is a pic of the
neck relief
. I'll take more if you want (the camera's being kind of a bitch though)
05:08 PM
Led_Fingers
06-26-2005, 07:06 PM
Led_Fingers
You know what , my bad, I'll take a pic on a flat surface in a sec, I'll have some bridge and trem spring pics also
Led_Fingers
06-26-2005, 07:34 PM
Led_Fingers
here's the bridge (little blurry, sorry about that)
05:08 PM
Led_Fingers
06-27-2005, 06:53 AM
dex
Posts: 1,972 - iTrader: (
Most probable cause is the 3 springs are pretty closed when the trem is at the correct angle so they don't feel spongy and the percieved tighness of the guitar is like on a
fixed bridge
Take the middle spring out and connect the 1 and 3 springs in / \ configuration, then crank on the spring claw holder until the trem comes back level and the guitar is in tune.
Having the springs more open will make them much more responsive and the strings will feel lighter to the touch because the trem will have more give.
ilia
dex
Find all posts by dex
06-27-2005, 03:01 PM
Posts: 19,352 - iTrader: (
Did you screw the springs in to get the trem into neutral position after you changed the strings? My guess is spring shock.
06-27-2005, 03:35 PM
sniperfrommars1
Posts: 3,302 - iTrader: (
Led_Fingers
here is a pic of the neck relief. I'll take more if you want (the camera's being kind of a bitch though)
Jesus christ that action is HIGH!!. is that a dobro?
sniperfrommars1
Find all posts by sniperfrommars1
bridge angle
edge pro trem
fixed bridge
gauge strings
neck relief
will edge zero pro fit edge 3 route?
how to get a nice tight distortion
what kind of strings does korn use
Edge Trem and .10-.52 strings (yes...)
saTa
05:19 PM
Replacing Strings on Edge Pro
GlassPrison2112
02:53 AM
Known history of Guitar.. (lots of people have it wrong) - a
vwall
Archived Topics and Common Questions - GO HERE FIRST
01:44 PM
vwall
02:20 AM
04:16 PM
