shim your neck & raise the Edge-Pro out of the body a bit.
you should then have all the pull-up you can handle.
...yes I know that doing this negates the purpose of the Edge-Pro being of lower profile than either ED or the LP.
I for one want to take the EP OUT of my '03 7vwh & replace it with the Original Edge!
The EP to ME is too stiff.
But, to each his/her own.
Peace!
Originally Posted by jalguitarman
The lack of pull up is why i want to convert to an older ibanez trem. I have noticed that on the low strings it will pull up a 5th until the b string which will pull a third and the e string will only go a minor third. I really find this quite odd.
