Old 02-11-2006, 11:30 AM
Chud  is offline
Posts: 926  -  iTrader: (0)
Edge Pro to Lo Pro...
I'm guessing this will need quite a bit of routing to do (or mabye not, i just dunno).
How would i go about putting a Lo Pro Edge or Original Edge into a guitar with an Edge Pro?
Old 02-12-2006, 12:45 AM
Ant1981  is offline
Posts: 2,181  -  iTrader: (3)
Re: Edge Pro to Lo Pro...
I think it says on this site somewhere that there would be a need for a bit of routing going on.
Is the Edge Pro really that crap?
Old 02-12-2006, 01:41 AM
ibanez.shredder  is offline
Posts: 310  -  iTrader: (0)
No it isn't. Quite simply that is bullshi*. The only real problem i can see is that is has no locking studs, a $30 modification. Most people just go ''oh it feels differnt so im just gonna change back to a Lo-Pro instead of adapting, its shi*'', but im not saying thats Chuds opinon. Why do you want to change it anyway? The EDGE-Pro is way more comfortable, and the saddle inserts give you better intonation, string life and sustain.
If you do want to change, yes there will be some routing required, and the stud will either have to be replaced, or have the locking stud mod done to them.
Old 02-12-2006, 02:29 AM
C.Thep  is offline
Posts: 3,050  -  iTrader: (18)
Are there any online stores that sell locking studs?
Old 02-12-2006, 05:14 AM
Right above you www.ibanezrules.com ^^^^^^^^
Old 02-12-2006, 02:36 PM
moro  is offline
Posts: 623  -  iTrader: (2)
I've had no problems with my Edge Pro. I do have the locking stud mod, though.
One reason I could see for picking the Lo Pro over the Edge Pro is that the former seems to have an intonation adjusting tool.
Old 02-12-2006, 02:52 PM
jemuniverse777  is offline
Posts: 307  -  iTrader: (0)
I had to do routing when going from an edge to an edge pro. The edge pro was wider at the bottom, it was something like 5mm I took off the body wall on the trem arm side. I eventually put the original edge back in because the edge pro didnt perform as well as the original edge. I kept getting this buzzing vibration on the high e that made absolutely no sense.
Old 02-12-2006, 05:04 PM
jalguitarman  is offline
Posts: 9  -  iTrader: (0)
My thing is; will converting one give to an origional edge more sharp pull up?
Old 02-12-2006, 05:33 PM
Ant1981  is offline
I've tried to get this tool, but it isnt available anymore
Old 02-12-2006, 07:40 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Rich has them.
Old 02-12-2006, 07:42 PM
No I hugely doubt it. I tested what you were saying out on my EDGE-Pro and EDGE, and you were right, but they had the same pullup range for low B, EADG and only at the high B and E did it start to fall down to 1 1/2 steps. I can't explain why it would do 6 steps on the low B, and only 1 1/2 on the high E. But the problem could be fixed by routing more of the cavity out to allow it more range of movement, that way you could keep the awesome EDGE-Pro.
It would be a good time to pipe in Rich! Why does the EDGE-Pro have less pullup range on the high B and E?
Old 02-12-2006, 07:44 PM
Seems like quite a minor issue though
Old 02-12-2006, 08:23 PM
Chud  is offline
The edgepro is a great trem system, i just find it alot harder to pull up on then other trems i own such as the Lo Pro.
I don't quite know why. I doubt it's to do with locking studs. The trem just doesn't seem to pull up as smoothly and doesn't have as much higher pitch range.
Old 02-12-2006, 09:19 PM
moro  is offline
Not for me. I dread adjusting my Edge Pro because the complete PITA it is to adjust the intonation. With my OFRs, it's not that big of a deal because I have the intonation adjustment tool.
Old 02-13-2006, 12:19 AM
Ant1981  is offline
Talking
Originally Posted by ryanb
Rich has them.
I need Rich then, PM me please.
allen wrench, equipped guitar, floyd rose, ibanez trem, local luthier, locking stud, locking stud mod, locking studs, low strings, pro edge, schaller trem, spring cavity, trem arm, trem guitar
Edge III swap for another Edge model trem? lespaulreedsmith Other Ibanez Guitars (including Premiums) 36 03-14-2009 06:10 PM
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
I just put an Edge in my RG470! DirtyBird31 Tech: Setup, Repairs and Mods 10 09-14-2007 12:22 AM
edge, lo pro and edge pro are 100% drop in fit dex Tech: Setup, Repairs and Mods 47 10-18-2005 12:29 PM
lo pro edge vs edge pro 7 cakewalkr7 Tech: Setup, Repairs and Mods 4 02-11-2005 12:23 AM
