Tech: Setup, Repairs and Mods
Edge pro to lo pro
02-29-2008, 11:18 PM
ChaosAndOrder30
Posts: 17 - iTrader: (
Edge pro to lo pro
I'm putting together an ibanez body a prestige 2570 and I don't have the
edge pro trem
. I've seen the pics where the wings of the lo pro trem hit the current routing. Could I just sand down the wings and a little bit of the body and it would work or are there other modifications>?
ChaosAndOrder30
Find all posts by ChaosAndOrder30
03-02-2008, 12:23 AM
albee1952
Posts: 784 - iTrader: (
Re: Edge pro to lo pro
The only way to fit the lopro without creating a piece of junk, is to carefully route t he opening. It absolutely can be done as long as you follow some precautions. First, go to stewmac.com and get a routing template for recessed floyds and a 3/8" template router bit. The template is not real thick and it will need to be raised above the body(best to probably get a chunk of 1/4 or 3/8 plywood from Home Depot). you can just cut an oversized hole in the plywood. cover the top of the body with blue painter's tape(to protoect the finish), tape the plywood so it can't slide around, then tape the template on top. Try to NOT overlap the tape on the template because the router is going to ride on top and a tape ridge will not help. Using a good carbide bit SHOULD make a nice clean edge without chipping the paint a lot(if at all). I have done this kind of mod on a few(just put an edge lo pro in a JS100) but it calls for patience and skill. Go slow, measure twice and route once. When in doubt, just do a little at a time. Time and tape is cheap. If you rush it or do it half-a$$ed, you will regret it.
albee1952
Find all posts by albee1952
03-02-2008, 04:32 PM
ChaosAndOrder30
I thought i only have to cut back the wings of the lo pro or sand back some of the wood by the wings of the lo pro a little bit for it to fit cuz that's all it looks like in the pictures
ChaosAndOrder30
03-02-2008, 04:36 PM
ChaosAndOrder30
like I could just dremel it out
ChaosAndOrder30
03-02-2008, 04:52 PM
TMatt142
Posts: 545 - iTrader: (
I think what albee is maybe saying is that the route for the lo-pro is a bit deeper as well. The entire trem on a lo-pro is recessed into the body. (Correct me if I'm wrong on this).
TMatt142
Find all posts by TMatt142
03-02-2008, 04:58 PM
ChaosAndOrder30
So what problems would I have putting a lo pro into my edge pro routed guitar
ChaosAndOrder30
03-02-2008, 06:24 PM
ChaosAndOrder30
http://www.jemsite.com/forums/showthread.php?t=68062
the two pics at the bottom of this thread make it seem ok and i emailed rich and he said sanding or dremeling back would do it but I want a second opinion just in case
ChaosAndOrder30
03-02-2008, 06:27 PM
ChaosAndOrder30
ohh and I think the first guy was talking about the
floyd rose
lo pro not the ibanez if I'm not mistaken (correct me if i'm wrong) because they only sell ones for floyd rose and schaller recessed trems not Ibanez
ChaosAndOrder30
03-02-2008, 06:36 PM
LonePhantom
Posts: 5,366 - iTrader: (
Reviews: 98
I've installed an Edge into a LO-TRS II guitar, just using some sand paper and a dremmel. If the Edge Pro posts are the same spacing as the Edge/LO Pro just sanding/dremmeling should be just fine. Take it easy, and it should be right. I put some masking tape down on the body to mark my lines to sand up to.
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
03-02-2008, 07:47 PM
ChaosAndOrder30
so is depth an issue cuz I was under the assumption i diddn't need to make it deep just a little wider in spots to fit it. And should I even bother touching the paint up? It's the vital prestige finish so it'd be hard. Or should I trim the tremolo itself down and not touch the body?
ChaosAndOrder30
03-02-2008, 09:55 PM
TMatt142
If anyone would know the in's and outs of these trems, it's Rich or the others. My only expertise I bring into this conversation is hour upon hour of searching through these threads on Lo-trs to edge pro or lo-pro modifications. More power to ya if all you have to do is sand the edges to make it fit!!!!
TMatt142
03-02-2008, 10:17 PM
LonePhantom
Reviews: 98
How much deeper do you need to make the cavity? You could always dremmel or route, or just shim the neck maybe?
LonePhantom
03-02-2008, 10:46 PM
ChaosAndOrder30
I don't know if you have to make the cavity any deeper I'm hoping not. I'm hoping i only need to cut back some wood or metal to save my self a hundred
ChaosAndOrder30
03-02-2008, 10:56 PM
ChaosAndOrder30
btw the neck is screwed in with screws with some glue on them to taking the neck off is definetely possible but I'd reather not do it since it's a hassle. So i'd rather not shim the neck as it's kinda in there good right now.
ChaosAndOrder30
03-02-2008, 11:32 PM
7@6-stringBUTCHER
Posts: 59 - iTrader: (
http://www.projectguitar.com/tut/trs2lopro.htm
this guy shows you how to fix this exact problem
7@6-stringBUTCHER
Visit 7@6-stringBUTCHER's homepage!
Find all posts by 7@6-stringBUTCHER
edge pro trem
equipped guitar
floyd rose
recessed trem
will edge zero pro fit edge 3 route?
how is the edge zero?
is my edge trem bar in all the way
edge pro to lo pro
rya
05-11-2011
03:54 AM
edge 3 to lo pro edge
hoockey
05:15 AM
Can I use Edge posts with an Edge Pro??
PatrickSimsCustomShopUSA
11:00 AM
String spacing of Edge/Lo-Pro vs Edge Pro
MetalZone
08:59 AM
Edge III Mystery... Solved?
eclecticmage
47
10-22-2006
01:08 PM
03:37 AM
