Old 11-12-2004, 11:17 AM
Stormcrow  is offline
Posts: 57  -  iTrader: (0)
Edge pro touching to the pickguard
The corner of the edge pro touches the pickguard a little (not the tremolo arm side)
how can I solve it
the guitar is a new jem
I adjusted the bridge height only ( I lowered it a little bit)
then when I see it touching the pickguard I raised the upper side and lowered the lower side and vice versa but there is still a slight touch
the bridge angle seems ok (tightened the back screws about a quarter turn)
and exactly where I must look for checking the angle the sides of the bridge are nut parallel to the saddles
and is it ok if the bridge is bent forward a little
the action is medium about 2mm on low E and 1.7 mm on high E and there is no buzz
Old 11-12-2004, 11:45 AM
Rich  is offline
Here ya go
http://www.ibanezrules.com/tech/setup/contact.htm
Old 11-12-2004, 11:59 AM
thanks when I first got the guitar it was not like this after I changed the biridge height it gets a contact in the corner
bridge angle, tremolo arm
