Old 05-30-2006, 09:03 PM
guitarman13  is offline
Posts: 388  -  iTrader: (0)
Edge Pro Tremolo Angle
The tremolo on my JEM7VWH is raised slightly above neutral. Everything else is adjusted perfectly. The only thing that bothers me is that the tuning stability isn't that great since the trem is not dead neutral. If a tighten the springs and bring the trem back to neutral, will it screw up the intonation and the action?
Old 05-30-2006, 09:06 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Re: Edge Pro Tremolo Angle
No it won't. Just undo the locking nuts (obviously!), then screw the trem springs it in a little bit and retune. Keep dipping the bar down after you adjust the tuning and raise it back up again. Keep going like that, making small adjustments to the springs and balance it against the string tension while the guitar is tuned to pitch until it's as near as dammit, then lock the nuts back up. Your action and intonation shouldn't be affected at all.
Old 05-30-2006, 09:11 PM
Rich  is offline
Posts: 19,350  -  iTrader: (21)
Action and intonation will both be affected, depending on how far off the angle is. Nothing will change action more than trem angle changes.
I've always found the best way to learn this stuff is to just do it and see what happened. We can tell you anything but it won't stick until you experience it.
Old 05-30-2006, 09:15 PM
The trem angle is barely off, but I want to get it just perfect. Will it lower or raise the action if I bring it back to neutral?
Old 05-30-2006, 09:16 PM
Dee  is offline
But Rich, he says it's raised *slightly* above flat. I doubt very much that the action will be affected in any noticable way. You are probably right, but hey guitarman, don't be afraid to adjust the bridge height with your allen keys just a touch if it happens to turn out feeling too high or low.
Old 05-30-2006, 09:21 PM
Rich  is offline
Slight trem angle change can mean 1mm in action, nothing will affect action more.
Like I said, do it and see, all you have to do is move your bar and watch the strings.
Old 05-30-2006, 09:27 PM
I have another question for you guys regarding the truss rod. Does tightening the tross rod raise or lower the action of the lower frets? I have a little bit of buzz on the low E string. Also, on the high E string, notes on the lower frets are somewhat hard to bend without my fingers slipping off of the string.
Old 05-30-2006, 09:32 PM
Dee  is offline
You should bend the first two strings (E and B) upwards towards the G string rather than downwards.
I'll leave Rich to answer the question about truss rods. I hate adjusting them!
Old 05-30-2006, 09:54 PM
jemplayer55  is offline
Posts: 2,627  -  iTrader: (0)
It took me forever (4 to 5 hrs.) to get mine neutral on my 05 JEM. Once I got it where I wanted I made a block to sit under the bridge when changing the strings and to get it back to neutral. I also took all the measurements with a set of dial callipers and wrote them all down. That includes trem claw distance (be sure it is even from body attachment points left screw and at right screw), trem height. action, trem body in relation to guitar body surface. Rich is dead on regarding trem angle and action.... once I got mine to neutral the action was much better and only required min. adj. on the trem height to eliminate any buzz. Again.... it's a long process but once you've got it, it's no problem to reset if necessary.
Old 05-30-2006, 10:00 PM
Dee  is offline
I also use a block when changing strings. Makes life much easier.
Old 05-30-2006, 11:02 PM
Racerx2k  is offline
Posts: 1,076  -  iTrader: (0)
Remember the old pink block erasers, they used to give us in school? Yup, I use those, under my trems, while I change strings. Works quite well, too, and it won't mar the finish.
Old 05-30-2006, 11:04 PM
That's a good idea, but I won't need to change the strings for a while, because they are brand spankin new. Does tightening the truss rod lower or raise the action of the lower frets?
Old 05-30-2006, 11:29 PM
Truss rod adj. is for string relief. Not action adjustment. It may help cure string buzz if your sure all the frets are level and there is not enough string relief. (ie: neck has a back bow, twist, fretboard distortion due to other problems.) Truss rod adjustment is best left to the pro's!!!! Not something you need to be messing with unless you've done it before and feel comfortable.
Old 05-31-2006, 12:55 AM
I just adjusted the springs in the back and have the tremelo floating perfectly level. But, the spring on the treble side is a little bit higher than the one on the base side. Is that normal? If it's not, how can I get them even with one another?
Old 07-11-2006, 12:17 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Not sure what you mean by "higher". If you mean one screw sticks out from the wood a bit more than the other, I would try to adjust each the same amount but in opposite directions till they are about equal. My method for setting the bridge angle uses several wood shims of varying thickness and I place them under the fine tuner area so the bridge sits at the nuetral angle. Then I screw the claw screws way in, string up the guitar and set intonation. Once that is done, I lock the nut. remove the shims and back the claw screws out (equally) until the guitar is back in tune. That sets the floating bridge exactly where it was when it was shimmed.
bridge angle, claw screws, guitar body, locking nut, locking nuts, rod adjustment, string tension, trem claw, trem height, trem springs, truss rod, truss rod adjustment, truss rods
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
WANTED: Edge or Edge Lo-Pro Tremolo Whammy Bar sfx70 Classified Ads: Guitars and Gear 2 01-19-2006 02:07 PM
Setting up Edge Pro angle rrhea Tech: Setup, Repairs and Mods 3 05-15-2004 12:02 PM
What is good angle of edge pro tremolo? Zelman Tech: Setup, Repairs and Mods 6 10-09-2003 03:58 AM
Correct angle for lo pro edge? big h Tech: Setup, Repairs and Mods 16 04-09-2003 01:25 PM
