Old 01-05-2007, 06:59 PM
ColinMmmmm  is offline
Posts: 1,068  -  iTrader: (1)
Edge Pro vs Edge Pro II vs. Edge Pro III
Hey guys - I tried to search for a thread that compared these bridges, but the search function would not recognize the words "pro" or "2" as they were too short. And there were like 500 threads that included the word "Edge". Anyway if you could point me in the right direction that would be fantastic. Really all I want is a double locking trem that will stay in tune - I dont think Ill use it that much. Ive heard the Edge III is pretty bad, but how is the Edge II? I played an RGT42DX and loved it - neck thru, mahogany body, but wasnt sure about the bridge . . . .
Old 01-05-2007, 07:26 PM
C.Thep  is offline
Posts: 3,050  -  iTrader: (18)
Re: Edge Pro vs Edge Pro II vs. Edge Pro III
the rgt42 has an edge pro II
The edge pro is the best out of the three.
Old 01-05-2007, 08:23 PM
-Rhaab  is offline
Posts: 479  -  iTrader: (0)
the edge 3 can be replaced buy the edge 3 i think, so thats good
zr is the best.. hah. I also tried original edge which is pretty good and feels more solid too, edge pro i would say is the best, or else it wouldnt be on the higher end guitars
Old 01-05-2007, 09:46 PM
Yeah I figured the Edge Pro is the best, but how much worse is the Edge II?
Old 01-05-2007, 09:50 PM
C.Thep  is offline
Edge Pro II is a pretty decent tremolo, I have a RGT42. Better than most of the typical liscenced F.R. tremolos IMO.
It is a hella lot stiffer and not nearly as smooth as the Edge Pro
Old 01-05-2007, 10:21 PM
LuredMaul  is offline
Posts: 764  -  iTrader: (22)
It is Stiff,but I have no probs with mine; But, I don't have problems with Lo-trs trems either
Old 01-06-2007, 12:57 AM
Ironjose  is offline
Posts: 1,057  -  iTrader: (0)
i always wonder that... does the edge pro II is good?
i mean ibz did switch the trs trems for ibz trems now and they should be good... and better than most licensed tremolos... but how does it stand against the edge pro... they´re kind of similar with visual difference that the edge pro has those chips on it and is longer and heavier... jajaja maybe those are the differences... jaja
JJ
Old 01-06-2007, 01:40 AM
Eddie_UV777  is offline
Posts: 1,179  -  iTrader: (3)
are the EP II's that stiff? cause i've had a Edge Pro on a 1527 and that thing was stiffer than an old man watching cheerleading tryouts
Old 01-06-2007, 02:01 AM
crevis  is offline
Posts: 2,599  -  iTrader: (1)
A 7 bunger has a bit more tension tho.
Old 01-07-2007, 01:30 PM
Ironjose  is offline
but is it good?
should it be worth buyin a mik guitar with it?
JJ
Old 01-07-2007, 01:46 PM
andy7jem  is offline
Posts: 6,504  -  iTrader: (0)
That is the quote of the week LMFAO
Old 01-07-2007, 05:19 PM
LonePhantom  is offline
Posts: 5,366  -  iTrader: (6)
Reviews: 98
Must have just taken some viagra cause he wouldn't have been otherwise!
Old 01-07-2007, 05:48 PM
Ironjose  is offline
could the edge pro II use viagra ???
jajajaja
JJ
Old 01-21-2007, 01:22 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Only diffeence I saw is the Edge Pro has the stainless steel saddle insert which(in theory) may give better sustain. I had an RGT42FM that came with the Edge Pro II and I dropped in an Edge Pro with no mods and no problems at all.
Old 10-31-2007, 02:18 PM
Tony G.  is offline
Posts: 5  -  iTrader: (0)
The "stiffness" issue totally depends on the number and elasticity of the springs in the floyd rose system. Put two "soft" springs in an edge pro II and it's like a friggin' JEM (okay, exaggerating, but prrrreeeeeettttyyyy close). I know cause I've done this myself, and I haven't noticed ANY difference between the Edge and Edge Pro II. Plus, it's a lot cheaper, and IMHO, beats the hell out of some original floyd rose "stiffies" systems.
floyd rose, locking stud, locking stud mod, locking studs, mahogany body, neck thru, trs trems
edge pro to lo pro rya JEM and Universe Guitars 42 05-11-2011 03:54 AM
Edge III swap for another Edge model trem? lespaulreedsmith Other Ibanez Guitars (including Premiums) 36 03-14-2009 06:10 PM
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
I just put an Edge in my RG470! DirtyBird31 Tech: Setup, Repairs and Mods 10 09-14-2007 12:22 AM
edge, lo pro and edge pro are 100% drop in fit dex Tech: Setup, Repairs and Mods 47 10-18-2005 12:29 PM
